Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 09-23-2010, 10:54 AM   #1
1975 31' Sovereign
Waterloo , Iowa
Entry door sprung-Airstream tech data on fixing.
I just found this data sheet on the airstream tech method for fixing sprung screen/entry doors.
robertel is offline   Reply With Quote
Old 09-23-2010, 11:17 AM   #2
Those are great instructions, but not for your 75.
The door frame is different and so is the lock.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-23-2010, 11:30 AM   #3
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Interesting. Where did that publication come from?
It is dated June 2009 so I presume it is referring to late model (2000era) units.
Is there any indication it is just for specific years and/or models?
My interest is in vintage (70s era) but will peruse this more carefully and see if there are many or any similarities.
Thanks for posting it.
Distantdrummer is offline   Reply With Quote
Old 11-19-2011, 08:54 AM   #4
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
I just wanted to share that I used the Airstream Tech instructions in this thread to correct the problems I was having with my entrance door. The door now works very well. I was about to take a trip to Jackson Center to correct my door problems.
Is there a library of these sort of Airstream Tech instructions somewhere that we all can get to?
Ridgerunner3 is offline   Reply With Quote
Old 12-07-2011, 07:14 AM   #5
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
Will this work for a '92 Excella? I have a similar problem with my door. Any help would be appreciated.
Jonathan Hettrick
'92 Excella 29'
'20 Ram 2500
AIR # 59179
Chillpoints is offline   Reply With Quote
Old 12-07-2011, 10:37 AM   #6
Silver Mist
LI Pets's Avatar
Riverhead , New York
Need a pic to see how bad it is, mine was real bad but got it back 98%
It can be done
Old 12-07-2011, 11:02 AM   #7
1992 29' Excella
Mine is not bad. I will get photos this evening. The top seal is away from the door frame approx. 3/8" and the bottom is only out about 1/4"
Jonathan Hettrick
'92 Excella 29'
'20 Ram 2500
AIR # 59179
Old 12-08-2011, 10:02 AM   #8
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
These instructions were also in the owner's manual of my 2004 25' Safari.
My door has an air leak at the bottom, but I don't think I want to completely de-rivit it to fix. I'm going to work on an additional thin strip of weatherstripping foam.
Thoughts?
Don
DJW is offline   Reply With Quote
1971 AIRSTREAM 29' AMBASSADOR Entry door required nascar427 Doors & Locks 4 08-20-2011 10:29 AM
