Old 05-26-2005, 10:45 AM   #1
Rivetedude's Avatar
Yorktown , Virginia
Send a message via Yahoo to Rivetedude
Entry Door Seals
Ok, in a previous thread (Warped Door), I mentioned that my entry door was warped and that the PO had put a big thick seal on the door all the way around the door and another thick seal on the coach around the top of the door jamb. I removed the seal that they had put on the coach and straightened my door. It was pretty easy using a 4x6 post and lateral preassure in various places. The door lines up perfectly with the screen door now which wasn't warped.
Now for the problem. My door still has a big thick white seal on it and that seal causes the top and bottom of the door to stick out. I don't want to rip that seal off until I find out what type of seal it's supposed to have.
My unit is a '72 29' International Land Yacht Ambassador. If someone with a similar unit could reply to this post with an attached pic of the original seal on the entry door or a link to the exact seal that it's supposed to have that would be great. Thanks!
Ben
Rivetedude is offline   Reply With Quote
Old 05-26-2005, 12:18 PM   #2
Ben.
You can see a picture of the correct door gasket for your trailer on our web site.
The part # is 45295.
That same gasket, in 72 is used for the windows and access doors.
Old 05-26-2005, 12:33 PM   #3
Rivetedude's Avatar
Yorktown , Virginia
Does that attach with double-sided tape? Does it come on the seal when you buy it?
Old 05-26-2005, 12:43 PM   #4
Ben.
Door gaskets that are attached with double sided tape on any Airstream product, is a guarantee of failure.
Use " 3M super weatherstripe adhesive" only.
That's the same material that the auto industry uses.
Contact cement is also useless for this purpose.
Airstream does have a door gasket with double sided tape for years later than yours. However, it must be installed with the #3M material.
Old 05-26-2005, 12:46 PM   #5
Rivetedude's Avatar
Yorktown , Virginia
Ok. I appreciate your help. Do you guys also carry the 3M adhesive?
Old 05-26-2005, 12:48 PM   #6
Ben.
Yes.
Old 05-26-2005, 12:52 PM   #7
Rivetedude's Avatar
Yorktown , Virginia
LOL @
Ben,
Yes.
Old 05-26-2005, 01:09 PM   #8
Images: 59
Originally Posted by Ironheadude
LOL @
Ben,
Yes.
Affirmative.
A/S entry mat bjstewart1 Upholstery, Blinds, Walls & Interior Finishes 30 06-29-2007 02:11 AM
AirstreamForums.com Member Sticker? Andy R Our Community 171 06-08-2007 11:12 AM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 10:08 PM
Keyless entry grogan Doors & Locks 2 04-20-2004 01:16 PM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 10:16 PM
