Old 09-09-2007, 07:51 PM   #1
1986 25' Sovereign
matthews , North Carolina
entry door latch
My exterior door latch broke this weekend. I could not close the door or I would have trouble getting in. Had to take a screwdriver to slide the slides to unlatch the door. I have a 86 25' sovereign. Anyone know who or where I need to call to get a new one?
thanks
monbro54
monbro54 is offline   Reply With Quote
Old 09-09-2007, 10:10 PM   #2
thanks
monbro54
The company that made that lock is out of business.
We have developed a lock kit, some time back, that works great.
Old 09-10-2007, 11:04 AM   #3
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
I just took my front and rear door latches apart to grease them up so they work a little smoother.Mine's an '86 Argosy,Maybe its the same type latch,I don't know. I did learn the front and rear are different sizes on mine. If you take your latch apart,look at the (pin) that holds the part you pull to open the door.I noticed it looks like that pin could move out of the grove and make the pull thing loose or,break off. Anyway,you may just have to reset or recenter that pin if thats the problem. Good luck! Brian
Brian,the proud (2nd) owner of aluminum 1986 '32 Airstream Argosy (Squarestream) #305 Rare? It's either the Hemi Cuda of all Airstream's,or their Edsel.
wanderer1 is offline   Reply With Quote
Entry door hinge TomW Doors & Locks 35 07-17-2008 07:04 AM
entry door handle lido&linda 85/345 General Motorhome Topics 14 06-27-2006 05:46 PM
Entry Door Locks LRPorter All Argosy Trailers 9 06-02-2006 01:20 AM
Entry door latch Larry Brown Classic Motorhomes 4 06-21-2005 08:39 PM
Entry door, what years fit? Toby Doors & Locks 4 09-16-2004 04:50 AM
