Old 11-29-2010, 01:13 PM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Entry door flew open while going down highway
The doors internal frame broke on both sides. Can this be repaired or will I have to find a donor trailer to fix this?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 11-29-2010, 02:04 PM   #2
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
I had this happen many years ago on a 1969 International. I was fortunate to know a very good welder who was good with aluminum. If you find someone like that be sure he is very careful to get the proper curve in the frame. once welded I pop riveted the skin back on and never had a problem. The guys on this site know how to use the right rivets so follow their advice and it will be better.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 11-29-2010, 05:14 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Get a good welder and next time use a wooden wedge in the grab handle to keep the door shut. We have a dead bolt but I don't even trust that.
Aaron
WBCCI #XXXX AIR #2495
Old 11-29-2010, 06:35 PM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Here we keep on going again......
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 11-29-2010, 09:15 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I had the same thing with a 65. Drilled off the inner panel, then cut two pieces of wood to match the frame curve and clamped them on to hold the shape. Took the door to a welder, good with aluminum, he tacked the break, then I drilled off the outer panel at his shop and he then welded the complete break. It was as good as new when riveted back together. Cost $60
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-29-2010, 10:02 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Same thing happened to our Caravel. It was my fault, as I neglected to use the dead bolt. There were two brakes, one just above the latch, the other just above the hinge.
I removed the inner skin and towed to a very good welder friend. Then I removed the door. We placed the door on the welding table and supported the top and bottom on 4x4 blocks. This closed the two brakes and caused the door to go back to it's original shape. This will only work if the frame is just broken, not bent. This can be determined by closing the broken door and pushing the top and bottom of the door at the same time to see that it still fits. Very easy after the inner skin has been removed. He welded a bead on the inside and outside of each brake, then ground down the outside beads to a nice finish in the visible areas. He then used some 1/4" thick aluminum to weld support gussets along the where the brakes were and one more at the bottom of the hinge area making the frame stronger than original. I towed back home and replaced the inner skin.
No problem since.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-29-2010, 11:15 PM   #7
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Fresh Air
I like your "door lock" design. I think that I will copy it for my 66 TW.
Thanks for the photo, Dan
Old 11-30-2010, 03:44 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Neil
Oooh nice!
Ought to market that
Mine is a bit more....rustic.
Aaron
Old 11-30-2010, 06:10 AM   #9
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
Same happened on my 66 tradewind due to dead bolt lock failure on our first 10 day trip on the first day. The door was the correct shape, but inside out. Removed the interior skin and located a heliarc welder. They welded the frame and I reattached the skin. Traveled for 9 more years before selling with no more incidents. I did take out the deadbolt and pinned it so it would never let loose again!
raveson is offline   Reply With Quote
Old 11-30-2010, 08:55 AM   #10
FreshAir's Avatar
1966 24' Tradewind
Originally Posted by TouringDan View Post
Fresh Air
PM me with your email address and I will send you a template.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 12-08-2010, 05:52 PM   #11
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
So if the inner skin is removed the door can be welded while still attached?
Rodney
and the
My Blog
Old 12-08-2010, 06:56 PM   #12
jal4509's Avatar
1977 23' Safari
Commerce , Texas
Outside door lock design...
Neil
Someone on the Forum made one with a rubber door stop & a tent tie bungee (has a plastic ball on the end). We used that idea and it works great. Sorry about your door!
Janet & Jim
"You can buy a cheaper burger, but then you gotta eat it." Texas Burger
jal4509 is offline   Reply With Quote
Old 12-09-2010, 06:35 AM   #13
raveson's Avatar
Boondocker, When the welding was done, the door was still on the hinges. In fact it made it easier to fit the contor of the opening with a couple of adjustments of the weld,
Old 12-18-2010, 07:38 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Here is my idea. works for me!
When getting ready to hit the road.
1. Store Steps
2. Secure the door
3. Raise the stabilizers
4. Disconnect power, water, TV, sewer, if applicable
5. Hook up TV, hitch; breakaway switch; UCord; safety chains
6. Raise tongue jack
7. Check all lights; tires and brakes.
If I don't do the steps and door first, I'll probably forget them.
I made a check off list, kind of like pilots do when getting ready to take off.
If I don't check it off. I'll forget it and that's not good.
It's still beyond me why after all of these years AS has not reversed the door.
ID:	117249   Click image for larger version
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
The open door dump... PaulO General Interior Topics 15 03-26-2008 07:12 PM
Door stop, door hold-open, whatever... bevman Doors & Locks 4 04-07-2007 12:27 PM
Help! Window Flew the Coup! airhead Windows & Screens 8 07-13-2005 08:12 AM
Tambour door won't open Rog0525 Cabinets, Counter Tops & Furnishings 9 11-29-2003 11:48 PM
