Old 06-21-2008, 03:53 PM   #1
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Entry door bolt lock with an outside key
Has anyone installed a dead bolt lock with the entry door - to be opened with a key? Thanks in advance for your comments. Bill
willyd is offline   Reply With Quote
Old 06-21-2008, 04:00 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Andy from Inland has asnwered this question a bunch of times and said it may weaken the door frame. I don't speak for Andy, and it's his original thought not mine. That makes sense to me. I'm not sure how it applies to an 86. As an alternative I put on a locking keyed hasp. Has a finished look and does not require any intrusive cutting etc. Stanley makes one. Low cost too.
Old 06-21-2008, 04:09 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The Excella has one OE Dexter deadbolt-keyed on both sides. Note that the bolt is modified to be thinner.
ID:	62651   Click image for larger version
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-21-2008, 08:41 PM   #4
Images: 59
I installed one in my '59. Vintage Trailer Supply sells the deadbolt with the thinner bolt, I think it is about 5/8" thick.
You need to plan the installation carefully, so the bolt only goes through the web of the frame channel. If you cut through the flange of the frame channel it will be weaker. You can't use a standard deadbolt, the bolt is way too thick.
Old 06-22-2008, 01:07 PM   #5
willyd's Avatar
1993 34' Limited
Thanks for the comments. I will proceed with caution. Bill
Entry door lock mandolindave Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 07-13-2007 12:32 PM
Missing Key for Potable Water Lock Door Streamer1 Doors & Locks 16 03-25-2007 08:00 PM
$60 to make key for lock inside handle SafeHarbor 1978- 1979 Excella 500 0 04-17-2006 06:30 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Numeric Entry Door Lock Combination/reprogram Tom & Janet Salhus General Motorhome Topics 6 06-09-2004 11:06 PM
