I am looking for the entrance door lock for my 1978 Excella 500. Do you also carry the parts for this lock? It is the 4" X 5 3/4" one and the key says Wartian Lock Company and PK 571 or possibly PK 577. The lock seems to work but the cylinder is worn.
Thanks for any help.
See post #67 above regarding Keeler Brass lock parts.
Because of that we came up with a kit lock that replaces Airstream locks from 1978 to 1991.
The door must be slightly modified, but very easy to do.
Andy, I have a 1978 Argosy that has the original lock with the small pin/lever that locks it from the inside and a screen. I am apprehensive that it will break and we will not be able to enter or exit. I would also like to install a newer lock/dead bolt set. What type of lock and dead bolt will work with my Argosy and will I have to cut the screen for the dead bolt to work?
Regards,
JC Squiers
Regards,
JC Squiers
Andy, Thanks once again for your assistance.
When replacing the 78 lock with your 22390 lock do I remove all of the old lock and plates then replace it with the 22390 lock and plates. Do I rivet it on and does it have a dead bolt? On another note can I put a window in my door and will I have to cut the screen to get at the new lock?
JC Squiers
Regards,
JC Squiers
After taking the lock apart numerous times and finding the kit from Inland RV, we took it apart one more time. The cylinder on the lock seemed to be worn and the key could move it up and down and the pin at the back that actuated the lock would slip in too far to work the lock. We are "trying" the lock after installing a small washer from the back side of the cylinder before the plate is put back on. This seems to stabalize the cylinder and the lock works each time we try it. We have not yet reinstalled into the door..... Since our door comes off at the hinges on the side with 4 screws and with two people can be carefully reinstalled, we will just keep the screwdriver handy in case it will not open again. I really would like to have a new or used cylinder in good shape to install, but I am willing to try this. If it does not work, I will revert to the kit and door alteration with the plates. I hope this helps you. If I'm not clear on any points, please let me know. Lots of luck, nicholaskmt
JC Squiers
The 22390 kit indeed has a regular lock plus a deadbolt. Both operate with a key.
