Old 05-01-2007, 02:25 PM   #15
Babeebloos's Avatar
1963 19' Globetrotter
Laguna Beach , California
Images: 24
Slamming???
Thanks Andy, I'll send my SAE today...only I want to also say that the lock will slide even without ...'slamming'...!
This has happened to me more than 3 times....a few times I had the key on me so no problem but there were 3 really BAD breakins I and a few really good and skinny friends helped out!
Debra
Officer says ..."Step AWAY from the toaster Ma'am"
http://www.debraschottfineart.blogspot.com
Babeebloos is offline   Reply With Quote
Old 05-01-2007, 03:50 PM   #16
Tincrew's Avatar
2007 25' International CCD
Ponderay , Idaho
Lock Fix
Thank you Andy~we've already had this happen to us several times and we've become paranoid about where the key is.
Tincrew is offline   Reply With Quote
Old 05-01-2007, 04:00 PM   #17
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I finally got around to fixing my screen door slider on the Excella. I am always loath to change the OEM look or add anything extra if I can get around it. The slider body is chrome over brass and thick enough to accept a spring and ball to make a positive detent. I used a spring (cut down) and a ball from a power window switch from an old Volvo.
ID:	36616   Click image for larger version
ID:	36618   Click image for larger version
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-01-2007, 04:44 PM   #18
Road Ruler's Avatar
Images: 38
Andy has always been a nice guy. His insructions guided me through the fix for my "out of shape" door. Many thnxs Andy!
Old 05-23-2007, 03:13 AM   #19
Johndigbydog's Avatar
1966 22' Safari
Eagle Lake / Eastport , Florida / Maine
Andy- I have a 66 A/S Safari with the old turn lock deadbolt supplied by airstream (it was more of a safety feature tyo keep the door closed in travel) anyway, both sides of the lock are intact but it appears the pin that acts as the actual deadbolt is missing or broken off, I can see inside the door and can view the mechanism moving. Any thoughts on obtaining a replacement pin? It seems that by merely removing a few pop rivets on the inside door skin will allow access to the lock. Thanks ! John
Johndigbydog is offline   Reply With Quote
Old 05-24-2007, 12:11 PM   #20
Airstream first used a travel lock in the 67 models.
I have no idea what travel lock you may have.
Can you post a photo?
Old 05-24-2007, 01:58 PM   #21
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Andy -
That's one of the nicest things I've seen offered in a long time. Thanks.
I just wish I was closer to California so I could bring my trailer in to you for service from time to time. Can you move farther east?
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 05-24-2007, 06:33 PM   #22
2005 30' Classic
Images: 12
Here are a few pictures . . .
ID:	37857   Click image for larger version
GetOutDoors is offline   Reply With Quote
Old 05-24-2007, 07:08 PM   #23
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Try this option, it works.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-25-2007, 09:11 AM   #24
You indeed have the 67 deadbolt.
Parts have not been available for at least 30 years. Perhaps you can fabricate something.
The shaft was nothing more than a round section of aluminum.
The correct operation from the outside is that you can "lock" and "unlock" the deadbolt.
The correct operation from the inside is that you can only "unlock" the deadbolt.
Old 05-25-2007, 09:54 AM   #25
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Virginia Beach VA needs an Airstream Dealer!
Originally Posted by flyfisher
Andy -
John
Safford RV is OK, but they don't specialize in Airstreams and they are 150 miles from me. How about opening a second location HERE, pretty please?
I know two people who need axle replacements... surely that will pay for the new location .
Thanks for your offer.
Paula Ford, Answer Center
Old 05-25-2007, 03:24 PM   #26
ScottW's Avatar
Hernando , Mississippi
Andy,
What a guy! Are new models (07's) vulnerable to the slam lock? Pictures looks like my door. I make a habit of always carrying a set of keys with me, and keeping another in the truck (accessible with the door code lock). However, it only takes ONCE!!!
Will be glad to make a 'donation'.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 05-29-2007, 06:01 PM   #27
Originally Posted by ScottW
Andy,
Scott.
Sorry.
You will need the kit too.
Please send us your SASE for a free repair kit.
Old 05-29-2007, 07:31 PM   #28
ScottW's Avatar
It's on the way. Thanks, Andy.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Wish AND FIX UP list for MH PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 35 07-25-2009 09:49 AM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
