Old 01-12-2013, 07:53 AM   #1
lewishw's Avatar
1978 31' Sovereign
Colorado Springs , Colorado
Entrance door keeper
The door keeper that is riveted to the side of my trailer (that holds the entrance door open) has gotten weak. The latch is fine, but the spring in it does not fully extend the latch anymore. Can I replace the spring in this latch without drilling the rivets, pulling it off and rebuilding or replacing it?
Stream on,
Hunter
lewishw is offline   Reply With Quote
Old 01-12-2013, 08:18 AM   #2
1986 31' Sovereign
Miami , Florida
Nope. But it is an easy job. You can get the guts to the keeper from out of doors mart or Inland RV.
Mike
Old 01-12-2013, 08:25 AM   #3
2008 16' Safari
Destrehan , Louisiana
Did you try to clean and lube it? Could just be a little crud in there.
dlb435 is offline   Reply With Quote
Old 01-12-2013, 08:30 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Outside Main Door Hold back 380291 [380291] - $5.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Alan
Old 01-12-2013, 08:42 AM   #5
lewishw's Avatar
1978 31' Sovereign
Thanks y'all!! I'll order that kit, caused metal housing is in good shape. I am super timid about drilling the rivets and tearing something up...how do I ascertain what size bit to use? I don't want to mar the skin by accident!
Stream on!
Old 01-12-2013, 11:06 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I keep an extra one in the trailer, just in case. I broke one when it got iced up and door hit it. It costs the same to ship two.
Richard
Old 01-12-2013, 12:07 PM   #7
2008 16' Safari
Rivets come in different diameters, lengths and material. You will need to use the aluminum rivets. Use the same size drill bit as the diameter of the rivets used. To keep from drilling too deep just put some tape on the drill bit about 1/2 inch from the tip. Don't drill any deeper than the tape.
Before you start: get some rivets, drill bits, tape measure or ruler, a rivet gun and a small peice of aluminum. Practice riveting small peices of aluminum together until you feal comfortable with the process.
It's find of fun.
Old 01-12-2013, 01:42 PM   #8
1975 27' Overlander
High River , Alberta
Inland RV or an industrial supply store will sell you the right drill bits. You need "number drills" which you probably won't find at a hardware store. The correct size is slightly larger than the rivet size so that you remove the old rivet cleanly without elongating the hole.
I looked this up online. The correct drill size for a 1/8" rivet is a #30, which has a diameter of 0.128", or 0.003" (three thousandths of a inch) larger than 1/8" (0.125"). The correct size for a 3/16" (0.1875") rivet is a #10 or #11.
AlbertF is offline   Reply With Quote
Old 01-12-2013, 02:37 PM   #9
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Once you have it off, easy. I had to remove mine to make the spring harder to accept the door, it would lock open when slight breeze push the door against the latch.
