Old 09-23-2016, 11:10 AM   #1
2005 28' Safari
Saint Joseph , Michigan
Electronic Door Lock
Last weekend we camped next to a fellow that had a push button door lock. After reading a thread about having to break into an accidentally locked AS we've been careful about keeping a set of keys in the keypad entry F150. Although the fellow said you have to be careful to keep fresh batteries in the lock, it seems like a good idea. Question is will this work with an AS, has anyone tried this, and if so, how was the install?
Camping World has this one:
TruckerFritz is offline   Reply With Quote
Old 09-23-2016, 01:44 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Seems like I looked at an ad for this same lock, but on a different site, and the verbage there said specifically that it was not for Airstreams. The issue would be that It looks like a drop-in replacement for the "Trimark" manufactured "standard" door latches common to other brands of trailer, but you would have to modify your door in order to make one fit an AS.
good luck!
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
Toad w/ electronic odo? GlenCoombe Classic Motorhomes 13 11-15-2007 12:18 PM
Electronic Stability Control important for safety rating Road Ruler Tow Vehicles 8 11-15-2007 12:17 PM
Hand held electronic voting rideair WBCCI Forum 2 08-13-2007 04:05 PM
Electronic Ignition Water Heater Broke drober05 Water Heaters, Filters & Pumps 2 08-06-2006 08:59 AM
