Old 10-08-2010, 08:58 PM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are running ST tires 65 lbs. would be right for 225 75 15 . If you are running LT tires 85 is right.
This is the chart. The pressures are standard for any given size independent of manufacture as the a Government Standards.
http://www.goodyear.com/truck/pdf/da...dInflation.pdf
2004 Excursion 4x4
Old 10-08-2010, 09:51 PM   #16
Originally Posted by mhilley View Post
Yes, that is the latch I have.
They are available in 3 and 10 pound ratings.
Original production used the 3 pound version.
If balancing the running gear and a reasonable tire pressure doesn't correct the issue, then the 10 pound latches will be your only answer without using some kind of gimmick.
They are not cheap. but they are not expensive either.
Using frig while in transit B&J On The Road... 64 07-04-2015 06:42 AM
Generator in Transit greatlakes Generators & Solar Power 3 08-04-2010 11:21 AM
MIA in transit!! 65 Caravel krikles Towing, Tow Vehicles & Hitches 28 07-16-2007 10:57 PM
Using gas water heater while in transit phippsto On The Road... 3 01-24-2006 06:18 AM
Microwave rotating dish in transit.... Silvertwinkie Off Topic Forum 15 04-23-2004 02:50 PM
