Old 08-18-2005, 03:10 PM   #1
tmeagle1's Avatar
1964 19' Globetrotter
Croswell , Michigan
Thumbs up Doorbell
I have an '85 Limited. It has a doorbell under side deadbolt. Can anyone tell me where the wires to whire up some chimes are? Thanks. I have a twelve volt chimer that came from the PO and would like to hook it up for kicks. Thanks again.
Tim Eagle
http://www.croswellmich.com (The New King of Horror)
tmeagle1 is offline   Reply With Quote
Old 08-18-2005, 03:16 PM   #2
I'm not sure about your '85, but the doorbell chime in our '81 is mounted in the curbside front corner, right beside the factory-installed speaker. Hope this helps. P.
Peter&Denise is offline   Reply With Quote
Old 08-18-2005, 03:32 PM   #3
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Wow! Another Eagle on the AirstreamForums! How rare is that? Glad to have you On Board.
Bob Eagle
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 08-18-2005, 06:05 PM   #4
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Wonder if they still offer them on the new coaches. Does anybody know?
Old 08-18-2005, 07:57 PM   #5
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
I don't know about new coaches, but my '79 Excella has it mounted behind the 8-track/AM-FM panel in the street-side credenza. It has a typical ding-dong "Avon calling" sound to it.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-18-2005, 09:13 PM   #6
Alden Miller's Avatar
1993 34' Excella
, Maryland
Same as...
I'm the same as Peter. If I pull the bin out from under the right side of my couch I can see the bell at the front right of the trailer. It goes buzzz buzzz buzzz but I'm not pulling the couch apart to fix it.
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 08-18-2005, 09:50 PM   #7
I am currently replacing the floor in my 91 excella. Here is a picture of where the doorbell is located in mine. Hope it helps. Gary
Duramax is offline   Reply With Quote
Old 08-19-2005, 05:42 AM   #8
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Easy fix
One of the easiest repairs as far as AS repairs go.
I have seen them on the forward wall as in the depiction above and I have seen them on the side wall (Street Side).
A buzzing sound is good, that implies that you circuits are good and you only need to replace the chiime with a typical twelve volt door chime, Cost around 20 dollars.
If you dont hear any noise, you may have a corroded button at the door. Simply pry the button out and check the connections. You can buy a replacement button at Home Depot, cost around four dollars.
There are about four wires at the chime. Two go to button and two go to source voltage. two small wires go to button two larger wires got to fuse panel or branch circuit.
Piece of cake!
smily is offline   Reply With Quote
Old 08-19-2005, 08:28 AM   #9
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
I just now took the doorbell button out of my Limited. Came out easy but was so corroded that the wires broke. Now I have to figure how to get at the wires. Any solutions?
About the same time the doorbell quit working my keyless entry quit. I can still get the bolt to move when I press two number buttons but it will not operate with either the personal code or the factory code. In the great scheme of the universe keyless entry is pretty insignificant. However, like a lot of others, if something is on my equipment I want it to work! Anybody have any experience with these?
I’ve sure been enjoying this site since I discovered it earlier this year.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 08-19-2005, 08:29 AM   #10
Still Working
smily's Avatar
1994 36' Classic 36
History
Did the Keyless ever work with either number?
Do you get any noise at all?
I have discovered that some numbers are pressed at the same time on the persoanl or factory code also.
Old 08-20-2005, 06:47 AM   #11
genearnold's Avatar
1992 34' Limited
Ken,
When I first bought the trailer in 1999 the Keyless Entry worked OK with both the factory code and my personal code. Yes, it makes a noise when the two buttons are simultaneously pressed (the normal way to lock the door). When I watch it with the door open, the deadbolt slides to the locked position but will not unlock when either code is inputted.
Gene
Old 08-21-2005, 03:33 PM   #12
tmeagle1's Avatar
Croswell , Michigan
Doorbell Thanks
Thanks everybody. I'm sure that is enough information to get it going and for the kids to drive the wife nuts ringing it. Thanks again.
Tim Eagle
Doorbell Craig 1978 Excella 30 09-10-2017 11:37 AM
Anybody else got one of these? guy99 Classic Motorhomes 16 05-25-2005 12:39 PM
Dead doorbell zracz Electrical - Systems, Generators, Batteries & Solar 7 12-19-2004 08:19 AM
Doorbell Fuse?- '88 345 Classic Mh jslee77 General Motorhome Topics 2 11-24-2003 06:03 PM
Dead doorbell on '92 30' fangthorpe Mechanics Corner - Engines, Transmission & More... 5 05-09-2003 10:00 PM
