Old 07-30-2007, 09:42 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Door will not lock from inside.
I searched the archives for this one specific problem but couldn't find anything on it. My main door lock works fine from the outside but I can't lock the door from the inside. Any ideas on what I should look for?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-31-2007, 06:31 AM   #2
A 1972 trailer came with a KT lock.
You will have to remove the lock to check the back side operation.
There should be a problem with the "vertical locking shaft."
KT lock parts are available, but just like a new KT lock, not cheap.
Old 07-31-2007, 07:30 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The second Bargman lock in my Trade Wind developed that problem almost immediately. It appears that door locks are a problem no matter what the year.
Vaughan
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
deadbolt with inside twist style lock cindy Doors & Locks 4 10-16-2002 08:58 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
