Old 07-03-2008, 04:07 PM   #1
Potters , Idaho
Door swap
If a door frame is cracked (cir 1967) and a door is in rough shape, can I replace with another door of a close vintage with out too much modification?
phoney is offline   Reply With Quote
Old 07-03-2008, 05:04 PM   #2
You can use a door from a 66, 67 or 68.
Cracked door frames are common and can easily be fixed.
We do it all the time.
Old 07-04-2008, 10:25 AM   #3
Potters , Idaho
Andy,
By fixed do you mean they are welded or are they removed and replaced? Does the door have to be from the same model or are they all the same?
Gee
Old 07-04-2008, 01:05 PM   #4
Andy,
Gee
The door can be from any model from those years.
The door frame and jamb that you have has not been available for over 30 years.
Drivetrain Swap GlenCoombe Mechanics Corner - Engines, Transmission & More... 3 03-30-2008 08:37 AM
AM FM swap pjude Classic Motorhomes 3 12-29-2007 06:46 PM
Converter Swap nairnchyz Batteries, Univolts, Converters & Inverters 4 11-16-2007 10:36 AM
P-30 Engine swap Bfrank Mechanics Corner - Engines, Transmission & More... 10 06-21-2007 07:00 AM
Bathroom Door Swap?? Janets Husband Interior Restoration Forum 0 01-28-2004 04:12 PM
