Old 04-06-2007, 11:31 PM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Door stop, door hold-open, whatever...
What should be used to keep the door from slamming against the side, bending the hinges, and denting the wall?
bevman is offline   Reply With Quote
Old 04-06-2007, 11:56 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Take a look at what Vintage Trailer Supply has to offer. I find them to be very friendly and promt with their service. The link above is what I have seen on vintage trailers - they have a lower profile model also.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-07-2007, 11:35 AM   #3
There is nothing available that will prevent the door from slamming against the side of the trailer, which usually results in a bent door, except you.
Don't let the door fly out of your firm grip, and you will never have the problem.
The door slamming against the side of the trailer, "WILL" damage the side wall. There is nothing to stop it.
Old 04-07-2007, 12:19 PM   #4
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
True Andy, I was only thinking of holding it once it was open. Yep, there have been times when the wind catches it that I could see the possibility of real damage. The item I listed above was only to hold the door once it is opened all the way.
Old 04-07-2007, 12:27 PM   #5
Short of a chain, , the latch and housing that is available has worked extremely well.
Part #'s 18777, 18781, and 18796 will get the job done.
Takes a couple of minutes to install.
Pantry - Door coming open gwsullivan Cabinets, Counter Tops & Furnishings 8 09-23-2017 06:21 PM
Tambour door won't open Rog0525 Cabinets, Counter Tops & Furnishings 9 11-29-2003 11:48 PM
Leave Propane Bottle Valves Open? heyskipper LP Gas, Piping, Tanks & Regulators 3 02-23-2003 08:19 PM
Sticking Dump Valve 74SovereignInt. Waste Systems, Tanks & Totes 12 10-05-2002 06:14 PM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 12:19 PM
