Old 08-06-2004, 10:41 AM   #1
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Red face Door Sprung? Repair or Replace?
I haven't had much luck on finding an answer in the archives on this question.
Trailer under discussion 1977 20' Minuet.
I believe my door is sprung, not what I would call the best fit.
What is the definitive answer to what is a good fit and what is considered a sprung door?
If the door is sprung can it be repaired, and how would one go about doing this?
If it can't be repaired, would a standard size Argosy or Airstream door fit the Minuet?
So many question so few answers.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-06-2004, 11:03 AM   #2
gvanman's Avatar
Howell , Michigan
I have a 1977 20' Minuet and also a 1974 31' Sovereign.
When I got the Sovereign, the door was sprung due to the PO fitting a dead bolt and drilling in to the door for the bolt.
I took the door off the Sovereign and swapped it with the door from the Minuet - it fits perfectly, so I am sure that it would work in reverse!
To remove the 'spring' from the door is not too difficult - I posted this previously (about a year ago).
What you have to do is remove some of the rivets which hold on the inner door skin - leave the top and bottom most rows of rivets in place and just remove the ones up the sides (you could probably leave the middle row as well as these hold the 2 skins together).
The next step requires 2 people - 1 inside the trailer and 1 outside.
The outside guy closes the door and pushes the top and bottom into place so that it fits properly and holds it there.
The inside guy has a drill and some pop rivets at the ready.
Any holes that do not line up on the skin, with the holes on the frame, need to be re-drilled and riveted. Once all of the rivets have been replaced, your door should fit perfectly.
I hope that I have not missed anything - you might want to search for the original post with my user name just to check.
Good Luck.
Cheers,
Dave Harris
'If you always do, what you've always done.'
'You'll always get, what you've always got!'
http://www.dpharris.com
gvanman is offline   Reply With Quote
Old 08-06-2004, 04:41 PM   #3
JohnG's Avatar
This may sound lik a dumb question, but exactly how do you know if your door is sprung? Is it that you can see daylight coming in from around the seal someplace? Or is it just stiff when you are opening it and get it to the 90 degree spot and gets loos again as you get it back to its 180 degree or the holdback?
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-06-2004, 04:50 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by JohnG
This may sound lik a dumb question, but exactly how do you know if your door is sprung? Is it that you can see daylight coming in from around the seal someplace? ?
John I can tell you for a fact that daylight may not be the deciding factor. I've seen at least two new Airstreams come from the factory with daylight leaks. Usually down on the lower corners.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-06-2004, 05:07 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Air Gap -- Me Too!
Originally Posted by jcanavera
...I can tell you for a fact that daylight may not be the deciding factor. I've seen at least two new Airstreams come from the factory with daylight leaks. Usually down on the lower corners.......
As does mine - about 1/4" on the lower non-hinge corner.....just tightened up the lower hinge (installed DOUBLE lock nuts - the lower hinge only stayed tight for 8 months or so since the last "tightening"). The latch side vertical door/casing seam is straight.
What can I do about the air gap? Anyone?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-08-2004, 09:56 PM   #6
JohnG's Avatar
Checked mine out throughly today. Found it to just be stiff. Worked in some lubricant and it seems much better.
John G
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
repair or replace a/c? hively Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-19-2004 11:37 PM
Duo-Therm Furnace (MH) repair or replace? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 12 12-30-2003 02:47 PM
Sink...Repair or Replace?? COArgosy78 Sinks, Showers & Toilets 17 08-05-2003 03:28 PM
1955 Flying Cloud Window and Vent Repair Steph Windows, Doors, Locks & Vents 2 08-05-2003 02:27 PM
