06-24-2011, 09:22 AM
Upgrading piece by piece
1967 22' Safari
Jackson
, Wyoming
Door sprung AND frame broken
My 67 Safari door has been through a lot of drama during the 5 years I've owned it. First the doorknob was off when I bought it -- PO said he took it off to polish the door -- so I put it back but it never worked quite right. Screws jiggled loose in California 2009 and locked our dog in, so locksmith pried door open, breaking the door edge. Spent summer 2010 with just the deadbolt, no handle. Finally got door knob fixed spring 2011 but they used a random lockset, not the long-tongue Bargman one, and moved the hole closer to the edge, patching with an aluminum plate.
Driving her home from repairs on Wednesday, I failed to deadbolt or bungee the door and it flew open and sprung. Upon closer inspection, I see that both sides of the frame are actually broken, and several rivets popped off so inner and outer skin are separated.
I'd like to find a door that's not so traumatized, but haven't been able to find one online.
I drank too much for two days while mourning.
Now it's time to put my big girl panties on and deal with it.
So off I go to the welding shop. Think good thoughts for me, please!
TAC: WY-1
Poverty with a view in Jackson Hole
06-24-2011, 11:23 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Good luck with the repairs, sounds like a real BUMMER!!!
Post some photo's if you can, there may be someone here that could help with parts/advice.
Love the old Safari's...had a 22' 63.
07-03-2011, 06:43 AM
1965 24' Tradewind
Starkville
, Mississippi
My door frame is broken too.
So, did welding the door work?
07-03-2011, 07:04 AM
1967 22' Safari
MILAN
Originally Posted by WOG
WOG, Don't know if you noticed this or not but this is a door only. It won't help with the cracked frame... There is however a listing in the forums parts/appliances classifieds for a door/screendoor/frame from a '70's AS that might be able to be used. Not original I know but at least it's an option. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
07-03-2011, 08:55 AM
1992 34' Limited
Grand Island
, Nebraska
Had the same thing happen in 1983 on one of my first tows with my '69 International. Thanks to a very good welder who knew how to weld aluminum I was able to salvage the door. Just remember, not al professional welders are created equal!
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
07-03-2011, 10:38 PM
1967 22' Safari
Jackson
, Wyoming
My DH asked me to wait and search for a new door before trying the welding. It would be $170 at minimum,and who knows if the fix would hold. Soo, any 1966-69 Junkers out there you're parting out?
TAC: WY-1
07-04-2011, 03:43 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Photo's
Stella,
Some photo's would help in your search for replacement parts.
07-04-2011, 07:09 AM
1989 25' Excella
1989 34.5' Airstream 345
Hobe Sound
When I had a 66 tradewind, the lock falted and the door flew open at 60+ mph. Needless to say the shape of the door matched the side of the TT only in reverse. Found a heilarc welder and I removed the interior skin, frame was broken on both sides! Welder did a great job refitting with the door still attached with the hinges. I reattached the interior skin and never had a problem again. Pinned the deadbolt so as not to allow failure again. Good luck!
07-04-2011, 07:44 AM
2020 30' Classic
Derwood
, Maryland
I know those of us with "suicide doors" in particular are told to always lock the deadbolt - so sorry this occurred - good luck!
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
07-05-2011, 10:22 AM
1965 24' Tradewind
Starkville
, Mississippi
doors and windows
Originally Posted by ROBERT CROSS
Stella,
This is what I'm looking for:
Door: 28 1/4" wide x 69 1/4" from highest point to bottom
Hinge: (only 1) 14 1/2" tall x 3 1/4" wide
Offset of door handle to edge: 4 1/2"
Windows: #1 - 18 1/4 W x 22 3/4" tall
#2 - 28 3/4 wide by 21 7/8
#3 - 28 3/4 wide x 21 3/4
#4 28 3/4 x 22 (could be 21 3/4)
The windows fit into a track at the top and have a place on the side for the slider bar that opens them.
I have attached pictures to help you see what I'm talking about.
Lindy
07-06-2011, 05:04 PM
steel/aluminum fabricator
2004 22' International CCD
Penticton
, British Columbia
Looks interesting Wog. I cant see a need for it though as you can have a part tig welded at a low cost at a fab shop. Using that stuff looks like solder so it might work if your part is sitting on a bench but having to weld something still installed would be impossible. 1 problem people dont realize is, once you try and repair something yourself with a product like alumiweld or JB weld and fail at it. You take it to a shop to be properly welded and most of the labour involved is grinding away all the foreign substance that is not aluminum. When you Tig weld aluminum it has to be perfectly clean. You can also mig weld aluminum which is a cheaper method usually used in production lines. I use a mig for tacking parts together but then tig weld so the weld is not questionable.
