Old 12-03-2014, 08:32 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Door sealing? How to know? Feeler gauge!
Here is the 'problem'..
Prior to replacing or adjusting my door on our Excella, I noticed our door did not seem to properly 'seal'... one hint was that you would hear a 'buzz' from the gasket as air sucks through the gasket.
So, I took a strip of paper... and closed the door on it so that the gasket was trapped.
Now I had a 'feeler' gauge!
I tested several points around the perimeter of the door by capturing the paper between the gasket and the door frame.. and gently pulling... making mental notes of the 'pressures' required to slide the paper at each location.
Next, I removed the gasket material and repeated the process.. nearly Zero pressure...
After install of NEW gasket, I retested and the pressure required to pull the paper 'feeler gauge' and it was significantly tighter...
Oh.. and the door closes tighter.. more snugly... hmmm.. good! So, rather than bending the door to reshape it, the problem was with the gasket all along.
Note... when I removed the old gasket, I found two layers of 'double sided' tape under the gasket!!! so, someone had 'shimmed' the old gasket in attempt to make it 'snug'... all along it needed a new gasket...
Oh.. Thanks to Andy at Inland for their excellent service and providing the new gasket material for the door!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-04-2014, 11:29 AM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Excellent! That's on my NEXT STEP list for ours, too!
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 10:45 PM
TAC : Feeler: TAC Rally in Minnesota Summer of 2011? ts8501 Other Rallies & Events 156 07-12-2011 12:06 PM
Feeler: TAC Illinois Rally May13 to May 15 Air Apparent Other Rallies & Events 13 04-18-2011 06:20 PM
TAC: Feeler/Poll: TAC Walt Disney World Rally 2012! exthemius Other Rallies & Events 40 03-10-2011 03:23 PM
