Originally Posted by safetyman Sounds like the door seal your talking about would work on just about any airstream door....I have a 69 and same problem..old and rotting rubber....wonder if this could be used on the windows as well...would make a simple job to replace rubber........where did you say you purchased this D rubber from, if I can't locate locally, I can all and have your dealer order for me............................Thanks! |
Use caution when changing to a different gasket from the original, especially the entrance door.
We replace dozens of doors each year because of the lock striker bolt or the stricker pocket has become excessively worn and by using the wrong gasket.
Doors can and will fly open from bouncing and simple vibration, but they also will fly open if the entrance door gasket is applying excessive pressure between the door and door jamb.
Some locks will actually open when that gasket pressure becomes excessive.
Before a person decides to change a door gasket to a different type, they might check around and see what the potential negative results may be.
Granted the "D" gasket is a few cents cheaper, but it adds considerable pressure to the door lock striker bolt and the striker plate. Should the door fly open in transit, it will cost a considerable amount of money to have it repaired and/or replaced.
You may wish to forgo the few cents savings, so that you don't take the risk of the entrance door opening in transit.
Of course, if Airstream reversed the door hinge, the problem would not be an issue.
But then, the front window would be blocked when the door was opened.
All the original door gaskets are available from parts stocking dealers.
The "D" gasket does work great on opening windows, since they cannot open by themselves, like a entrance door can. We have used it on windows from 1990 on back into the late 50's with great success.
Use caution when installing the "D" gasket when making a square corner. Do not cut and miter the gasket at the corners, but simply make a small radius corner, along with using the 3M super weatherstrip adhesive which out performs other adhesives.
