Old 09-15-2007, 07:09 PM   #1
1964 19' Globetrotter
Portland , Oregon
door replacement '64 Globetrotter
Someone, sometime, used my 1964 Globetrotter for target practice. Thankfully, they just put one bullet through the trailer. The bullet exit hole went through the door. The trailer has a double door and the inside door was damage. Can this door be repaired ?? at what cost?? If it can't be repaired, can it be replaced?? at what cost?? Any information would be appreciated. Thank You
64tr0tter is offline   Reply With Quote
Old 09-15-2007, 09:04 PM   #2
The smaller door can easily be repaired, by someone that knows how.
The exterior door, is a different matter.
If the extrusions are damaged, you either have to have some made, or bring the trailer to us, as we have a few of those extrusions left.
You cannot with any degree of accuracy, repair the exterior door, unless you have the trailer with it.
Back then, that particular door was twisted and adjusted for each trailer.
Rarely will a door from another trailer properly fit a different trailer, without major changes.
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
need replacement '64 Globetrotter door trotter594 General Repair Forum 0 04-29-2012 05:14 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
