Old 05-29-2007, 02:31 PM   #1
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Door out of whack
Can someone help me with a door problem. If the picture gets posted....you can see that the lower part of my door is sprung out of shape on my 28 ft Argosy MH. It appears that it is ok from the middle hinge on up to top of door. From the hinge to the bottom of the door its sprung. the door opens and shuts easily. Any suggestion on what I might do to correct this problem.
ID:	38206   Click image for larger version
tn2... Bad thing about doing nothing is you never know when you're done.
tn2 is offline   Reply With Quote
Old 05-29-2007, 02:37 PM   #2
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
If that was a TT I could tell you exactly what was wrong, since it is a MoHo, I think you will have to remove and re-hang it. I have seen that on trailors before where the frame is jacked to high or sagging badly.
Good Luck,
Dave
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 05-29-2007, 03:05 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
It sure looks like the door on my Argosy TT -- the victim of a slow speed lock failure. The angular momentum of it opening is huge by the time it gets back to the hold-open latch. See http://www.airforums.com/forums/f453...oor-26820.html. It's a project I have to do too. Against better advice I have tried banging and it gets me worse than nowhere. See the ideas that LI Pets and Inland Andy have about removing and using new rivet holes. Let us know how it turns out!
5 meter Langford Nahanni
Old 05-29-2007, 04:02 PM   #4
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Door rerig
By doing the method of building a wooden gig...I wonder if it would be necessary to unskin the complete door.....seems like it might be possible just to do the lower half ( in my case). I think I will have to think a bit more about this. Hate reinventing the wheel if it's already been done by someone.
Isn't this restore business fun....YIIIPPPEEE
Old 05-29-2007, 04:15 PM   #5
tn2 -- You might have a good point there. Be sure & check the rest of the door with a dollar bill -- you're good to go if you can't easily pull it past the gasket with the door closed.
Certainly give up on all the gasket and replace it completely when the job is done.
Old 05-29-2007, 05:50 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Make a jig out of a 2X6 and try it!
ID:	38211   Click image for larger version
'77 Sovereign Intl 31' CB
Old 05-29-2007, 06:08 PM   #7
Remove all of the inner metal.
Realign the door.
Reinstall the inner sheet metal, "BUT DO NOT" use any of the original holes.
Drill new holes completely.
Check out the door. It should fit correctly.
Now, and not before, reinstall rivets in the original holes.
The new riveting will hold the door in it's new alignment. If you used the old holes, you would permit the door to back to it's warped shape.
Old 05-30-2007, 12:25 AM   #8
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Just a thought - IF you know the complete history of the door/MH, and that it HASN"T flung open, then I'd think the door hinges have loosened from the shell side, and the door is sagging down. The fix is to remove or drill access holes from the inside, and replace the nuts with either double locknuts or lockwashers and nuts (of course, after rehanging the door up higher so it isn't sagging).
If it's been flung open, disregard my advice.
Marc
Nice MH by the way!
Old 01-16-2008, 06:17 PM   #9
Thanks for all the ideas on this. The door in my 68 Overlander is flush on the bottom and a good 1/2"-3/4" open at the top. I am going to start with the 2x4 with the door still mounted... if that fails to fix it I will pull the interior skin and try again. If it is still being stubborn then I will pull the door and make the jigs. It's only getting up to the 20's here by day and I don't have an inside space to work so I wonder if the temperature will have anything to do with my success.
Thanks Again.
jyobp is offline   Reply With Quote
for sale parting out an entire airstream inside and out jazzy13 Airstream Classifieds 3 09-01-2015 03:31 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Slide-Out Won't Go In or Out AGEMMEN Limited slide out models 1 09-02-2013 06:40 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
Refrigerator out, oven out hampstead38 1967 Overlander 0 10-19-2008 07:56 PM
