Old 01-31-2007, 09:27 PM   #1
2007 25' Safari FB SE
Fallbrook , California
Talking Door not closing with stabilizer in place
I have a 25 front bedroom LS,SE. I have had problems closing my door when I set the rear stabilizer on the door side of the AS. On my last trip I was parked on a pad that had a slight slope (running down from the rear of the AS to the front) I leveled the AS then set the stabilizers. The door was what I would call out of plumb. The bottom of door extended away from the body by approximately 1/2 inch and would not close. I backed off the stabilizer until the stabilizer was off the ground and the door came back in plumb. I am suprised that having the stabilzer set would move the door out of plumb. I read in my owners manual that (page c-3) when leveling on rough terrain use jacks and the position of the jacks is indicated in a drawing on the same page. Are Hydraulic jacks typically used to level on uneven pads? Has anyone reported this problem in the past discussions?
Comments and Advice appreciated
KM
silverhawk25 is offline   Reply With Quote
Old 01-31-2007, 09:46 PM   #2
1994 30' Excella
Mississauga , Ontario
The stabilizers are to be used only to prevent movement in the trailer when you walk around etc.
You don't use them to get the trailer level.
If I get one of mine too tight it has the same effect.
Al
Old 01-31-2007, 09:54 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my understanding of leveling the trailer is to level side to side with the wheels. You may need blocks or something else to raise a wheel or wheels on the low side. Then the tongue jack will level your trailer, front to back. Then lower the stabilizers to "Stabilize. Done!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-31-2007, 10:01 PM   #4
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Rear stabelizer goes at the "back" of the trailer. not the side. If you want to eliminate movement then get some sizzer chocks that go between the tires.
R/
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 01-31-2007, 10:01 PM   #5
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
ditto big al
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 01-31-2007, 10:02 PM   #6
KM
The Bal jacks are for stabilizing only. They will break if you use them for leveling.
For leveling, use some 2 x 6's. They are cheap and work great.
Old 01-31-2007, 10:42 PM   #7
Excella3287's Avatar
The ones from Camping world used for leveling side to side are just classier and not expensive and come with their own carrying bag.
Excella3287 is offline   Reply With Quote
Old 01-31-2007, 10:56 PM   #8
TIMEMACHINE's Avatar
Huntington Beach , California
I agree
Not to mention no splinters.
TIMEMACHINE is offline   Reply With Quote
Old 01-31-2007, 11:46 PM   #9
Suburbia , Sunny So Cal
I use scrap 4x4's. Not as fancy as Timemachines but if I don't need them I can always toss them in the campfire.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 02-01-2007, 07:23 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
The yellow blocks from Camping World broke on me the second time out. I've seen the orange ones (can't remember the manufacturer) which seem to be of better quality. I'm cheap so I use 2X6's or 2X8's to level.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-01-2007, 07:31 PM   #11
Leveling Blocks
Breaking...........I've been using the same blocks for years and a chip hear and there ,my fault but still usable. Camping world has them on sale right now a package of 4 $14.99 a package of 10 $19.99....hmmm that's $1.99 each.
best place to order trailer appliances... Neenm General Interior Topics 5 10-23-2013 01:47 PM
Steps Opening And Closing For No Reason wb13798 Mechanics Corner - Engines, Transmission & More... 22 07-15-2005 06:06 PM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
what holds black water tank in place tw64 1959-69 Tradewind 3 06-16-2004 11:05 PM
Need a place to park gwsullivan Our Community 2 11-15-2002 07:19 PM
