Old 12-19-2007, 05:44 AM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Door mechanism on 1955 Safari
This is a picture of my 1955 Safari door mechanism, is it a Bargman H20-2 Door Handle?.............thanks
toastie is offline   Reply With Quote
Old 12-19-2007, 07:11 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Hi toastie. Yes, you have a Bargman H 20 door handle. A few parts are still available for that mechanism. Check out
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
PS Don't allow just anyone to try to open that door. You know why, it TURNS but most people try to PULL and end up breaking it off.
Good luck...
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 12-19-2007, 09:19 AM   #3
toastie's Avatar
1955 22' Safari
Originally Posted by Silverhobby
Yes, you have a Bargman "H 20" door handle. A few parts are still available for that mechanism. Check out
Good luck...
Is it a Bargman "H20-2" and thanks very much on opening of the door..........
Old 04-21-2008, 08:16 PM   #4
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
H20-2 Parts
Right now, only the handle and the handle spring are available as replacement parts. We're hoping to track down and offer the bezels and the cylinders, too. But they're not available yet. They were used on very few makes of trailer so they're one of the rarest locks. Only the L-77 was used less.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Old 04-21-2008, 08:49 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Warning Hijack
I need a knob and dead bolt like this one for my Liner.
Bill
Just my personal opinion
Old 04-28-2008, 08:27 AM   #6
VintageRV's Avatar
1956 22' Caravanner
1954 Locks
Hi Bill,
That's a pre-H20-2 lockset. The knob is a standard commercial grade aluminum exterior passage-type set. No cylinder. I can't vouch for your backset. That's the critical measurement. Measure from the center of the knob to the edge of the door and I'll see if I can spec something.
The deadbolt is probably a standard single cylinder RV deadbolt. Again, check the backset to be sure. When you buy a deadbolt, make sure it works on 1-5/8" thick doors. that's about what you have, if my memory is correct.
Good luck and post again if you need additional help.
Bill
Steve Hingtgen
WBCCI #1573
Old 04-28-2008, 09:19 AM   #7
VintageRV's Avatar
1956 22' Caravanner
Oops. I meant stainless
Originally Posted by VintageRV
Hi Bill,
...The knob is a standard commercial grade aluminum exterior passage-type set...
I meant that's a stainless steel passage-type set.
Steve Hingtgen
WBCCI #1573
Old 04-28-2008, 10:46 AM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Hi Bill,
Steve,
Thanks, I will send you some pictures and measurements.
Did you get my email on the taillights?
Bill
Old 03-25-2010, 09:12 AM   #9
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
hello --i'm looking for a bargman H20 lock set or just the parts that i need for my 56 bubble. i need the shaft that attatches to the exterior handle connecting to the female internal lock, the hardware that attatches/keeps it on the handle and the handle itself. let me know if you have all or part f this setup. regards--ted
the544man is offline   Reply With Quote
Old 03-25-2010, 09:33 AM   #10
pbearsailor's Avatar
Port Hadlock , Washington
I'd be watching eBay for an H-20, they come up every so often. I've seen them go for $300, but I got a spare for $75, so you never know. Sure seems like one of those parts that it would be really good to have a spare on hand.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 03-26-2010, 09:29 AM   #11
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
h20 lock
do you still have your spare? wanna sell it or part of it? i just need the larger shaft that goes from the exterior handle and into the lock itself--and whatever small pins and things that hold it in. the rest is complete and seems to be functioning ok. i can get a new handle from vintage t-s. regards--ted
Old 03-26-2010, 09:59 AM   #12
I do, but I didn't mean to imply in my reply that I wanted to sell it. Sorry.
-steve
Old 03-26-2010, 10:03 AM   #13
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
me too
I got the handle from Vintage...now I need that connecting rod....do you think a 1/4 in. standard door rod can be modified? Does anyone have the remnants of the broken lock...did not want to got the expense of the new handle.....they would part with? Know where some are?
Toasties' picture....
Name:	bargman lock handle 9 jpg.jpg
Old 03-26-2010, 02:47 PM   #14
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Just a Q. Are these parts made of bronze? I know of a fantastic foundry that I have used when I need to recreate something. I found a part to a boat that was on a friend's yacht. I begged him to let me borrow it. I had a dozen pieces made. And honestly, I didn't feel it was that expensive...
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
1955, 1955 safari
Looking for 1955 Safari wiring diagram toastie Electrical - Systems, Generators, Batteries & Solar 1 04-27-2008 05:00 PM
Our new baby....1955 Safari toastie 1955 Safari 12 12-08-2007 08:12 AM
Looking at a 1955 22' Safari toastie Waste Systems, Tanks & Totes 3 11-21-2007 03:28 PM
Door Knob for 1955 Liner dlx25225 Doors & Locks 19 04-25-2007 07:13 PM
Door lock replacement for 1955 trailer "?" RichardT 1950-1955 Flying Cloud 2 10-12-2005 06:29 AM
