Old 12-03-2006, 07:02 PM   #1
aproned dad
roamingwesty's Avatar
1968 17' Caravel
Carmichael , California
Images: 12
Door lock repaired, 1966-1969
Symptom: Outside door knob turned but not engaging. Couldn't open door.
Fix: (after the door is opened,)
1. Take out inside knob and plate (3 screws total) and the cam - the square profiled axle that turns the lock, watch out to not lose the spring on cam.)
2. Take out the striker plate's 2 screws.
3. Take the remaining lock assembly off the door from the outside.
4. Start taking the assembly apart slowly. From the attached picture, see lock01.jpg, the beginning of this step.
http://www.airforums.com/photo...?i=14084&c=502
Notice the little metal stud on the housing near a screw. That's the only stud on the plate, and the bolt when assembled should be pointing the opposite way.
5. After the screws are removed, the bolt and its plate comes off, watch out not to lose 2 springs in this part. Then the copper cylinder plus its plate below. See lock02.jpg.
http://www.airforums.com/photo...?i=14083&c=502
6. Now the exposed plate can be taken off. This plate controls the locking from the inside knob. It should go back on in the same position.
7. Now we're at lock03.jpg, exposing the problem.
http://www.airforums.com/photo...?i=14082&c=502
Now on top is a washer. It should be held on by the metal in the center being flared out. Underneath that washer is the movement plate for the outside knob. When the washer pops loose, the movement plate will also be loose. Its result is the outside knob will not work.
The fix is to push the washer back in, and flare the metal out again to hold the washer in securely. See lock04.jpg
http://www.airforums.com/photo...?i=14081&c=502
I used whatever happened to be handy in the garage. Put the knob on a piece of soft wood that has some give so the knob is not damaged in the process.
8. Doublecheck when done, to make sure that this time the washer is not going anywhere. Clean up and lube moving parts with grease. See lock05.jpg.
http://www.airforums.com/photo...?i=14080&c=502
9. Reassemble in reverse order.
The only caution I can think of would be to do it slowly/carefully. In the last picture one can see a rectangular shaped part. That part helps lock the door by turning the knob when inside. It slides left to right and is held in position by a spring and a ball bearing. I'd hate to see these parts lost, or any of the other springs.
I hope this helps anyone who faces this little problem. This procedure should pose no threat to the integrity of your airstream security. You have opened the door to get to the lock, after all.
Please feel free to add info or correct any mistakes.
Ricky
roamingwesty is offline   Reply With Quote
Old 12-03-2006, 07:49 PM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
This is great info. Thanks for documenting it so well for future reference. Karma to you.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 12-03-2006, 07:56 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Great work!!!
Thanks for the great job. Too late for me,,,,but, I have a spare lock now that I can fix.
Old 12-03-2006, 08:17 PM   #4
aproned dad
1968 17' Caravel
Images: 12
Thank you both!
Old 07-15-2007, 09:47 AM   #5
JW84345's Avatar
1969 27' Overlander
, Michigan
Thanks for the info.
I will try this on the lock to my '69 Overlander. It exhibits the same symptoms, started while on the outerbanks this last week. I dissamembled it and put it back together on site, and was able to get it to open by presssing and turning at the same time. The washer was definately loose and the exterior handle came right out, so I will try this fix.
If it does not work, I think I will pick up a bargman L100 for about $40 on the internet and attempt to use my existing (longer) yoke. Any thoughts on that??
JW84345 is offline   Reply With Quote
Old 07-15-2007, 10:49 AM   #6
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Inland RV
Before you give up, make sure you give Inland RV, Andy, a call. There are several threads on locks. Even a locksmith fixed ours on the Argosy Minuet.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 07-15-2007, 01:07 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I would also suggest putting anti seize on all screws. The plunger in my 67’s lock broke blocking retraction from the striker, trapping me in the trailer. When I tried to disassemble the lock, one of the screws on the inside was frozen and the Phillips head stripped out. It took me hours to get out. When I replaced it, I removed every screw and put anti seize on them. Some were amazingly loose, too.
Vaughan
Old 07-15-2007, 05:24 PM   #8
JW84345's Avatar
1969 27' Overlander
, Michigan
Ricky's fix worked great. Door lock works like new. I'll keep an eye on those screws. Thanks.
I'm still planning on ordering a new Bargman L100 and keeping it on board. I saw one on the internet for $39. Good, cheap insurance.
Old 11-02-2008, 12:31 AM   #9
Airstray's Avatar
2003 22' International CCD
1977 31' Excella 500
1966 26' Overlander
Shelton , Washington
Images: 13
My 66 door lock is missing parts. If you can tell me how to post pictures, I'll send a picture and explain. Thanks, Airstray
Airstray is offline   Reply With Quote
Old 11-02-2008, 12:55 AM   #10
Airstray's Avatar
1966 26' Overlander
Images: 13
Thumbs up 66 Door lock!!!!
Name:	Logs Jimmy & <a title=1966 Airstream 059.jpg Views: 208 Size: 385.4 KB ID: 70692" style="margin: 2px" />
Name:	Logs Jimmy & <a title=1966 Airstream 060.jpg Views: 356 Size: 258.8 KB ID: 70693" style="margin: 2px" />
Name:	Logs Jimmy & <a title=1966 Airstream 061.jpg Views: 163 Size: 416.9 KB ID: 70694" style="margin: 2px" />
Name:	Logs Jimmy & 1966 Airstream 062.jpg
ID:	70695I figured it out. As you can see, parts are missing. I can purchase a new lock from Inland RV but wish to keep my unique handle. Thanks, Airstray
Old 12-20-2008, 03:17 PM   #11
Airstray's Avatar
1966 26' Overlander
Images: 13
Originally Posted by Airstray View Post
Attachment 70692
Attachment 70693
Attachment 70694
Attachment 70695I figured it out. As you can see, parts are missing. I can purchase a new lock from Inland RV but wish to keep my unique handle. Thanks, Airstray
I lucked out and picked up a new lockfor $30. on eBay. Thanks, Jim
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
1966 Overlander International Twin Bed Action 1966 Overlander 6 10-04-2004 06:12 PM
electrical diagram for a 1966 Ambassador 28 foot ups guy Electrical - Systems, Generators, Batteries & Solar 2 09-10-2004 04:24 PM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 11:01 AM
