Old 04-24-2008, 12:19 PM   #1
1988 34.5' Airstream 345
bemidji , Minnesota
Door lock problem
I have a 1988 classic 345 airstream motor home with a working door lock that is getting worn and sometimes does not catch. There are two "philip type" knobs that stick out of the lock side and fit into a latch on the body side. THe knobs that stick out are wearing irregulary and are out of round. Can they be screwed out and replaced? If so are they a standard screw or a special part?
lorca is offline   Reply With Quote
Old 04-24-2008, 02:29 PM   #2
Silverhobby's Avatar
Greeeneville , Tennessee
You may have a Bargman L-300 lockset. Do a search for Bargman Lock. I found a diagram that shows a parts breakdown. If this is the lock, there is a rebuild kit available.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 05-02-2008, 02:31 PM   #3
bemidji , Minnesota
Thanks for the information about the Bargman L-300 . It is hard to tell if this is the lock I have. It looks similar but not exact. I looked online for a rebuild kit and could not find one. Lorca.
Old 05-03-2008, 12:28 AM   #4
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Send a PM to member InlandAndy with your question. He stocks a lot of that stuff.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-03-2008, 07:11 AM   #5
Those screws are a part of the lock, and are special to it.
They are bot ordinary screws.
I am not aware of a source for just "those screws."
The cause for the problem, is lack of proper running gear balance.
The entrance door is shaking up and down, which in turn, causes the wear you have described.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-04-2008, 09:25 AM   #6
bemidji , Minnesota
Thank you Andy for the reason that our lock has the problem it has. We will make sure that we watch that carefully. The problem is that we bought the Rv with this problem lock the way it is and want to replace it and are having a hard time trying to find a replacement. Once we get a new lock we will be careful to prevent this from happening while we are the caretakers of the RV.
Can you give us any more information on the type of lock we need. The L300 has 3 parts according to a web site I was on. They sell all 3 parts. I called the site on Saturday and the man said that there is one extra part that the airstream needs that is not listed but that I had to call back on Mon. I am not sure that this is the lock that fits the Airstream as the site was a general RV site and not an airstream site.
Old 05-04-2008, 10:16 AM   #7
We have the replacement lock, with instructions.
Andy Rogozinski
Inland RV Center
Corona, CA
Door Lock moveinon Doors & Locks 15 02-06-2020 07:24 AM
Door Lock Robin Stone Doors & Locks 8 03-06-2008 04:27 PM
Lock Operating Problem fireflyinva Doors & Locks 5 06-12-2005 05:14 AM
'71 Sovereign LandYacht Door Lock Problem mtjim Doors & Locks 14 01-06-2005 03:29 PM
Another annoying lock problem - 1988 Door? Condoluminum Doors & Locks 0 07-06-2004 05:39 PM
