Old 04-22-2009, 08:51 AM   #21
papagord's Avatar
1974 25' Tradewind
Midhurst , Ontario
You are so right about that Grant. UPS charges $35.00 plus GST whereas Can Post charges only $5.00. Last year I bought a power center from the US but they wouldn't ship by any other means than UPS. They probably could but didn't want the bother. I did buy a lock that cost $60.00 incl tax but I couldn't adapt it as the inside extended out too far from the door surface and interfered with the screen door. Also I would need to fashion an aluminum plate to cover the 9" hole left by removing the old one. I'll let you know how I make out. I'll be going to the RV Centre Friday morning.
papagord is offline   Reply With Quote
Old 04-27-2009, 08:57 AM   #22
Cincinnati , Ohio
Originally Posted by chrisd37 View Post
Thanks Andy. I will use my tin snips and get to carefully installing that lock later this afternoon. It's definitely a better lock than the original that is sold at 2x the price and (presumably) would have the same fail rate as the original failed one.
You will probably need RH snips and LH snips. Most manufacturers make them red handled for one and green handled for the other. I don't remember which is which.
The proper tool will make the job so much easier.
Woody
Woody.303 is offline   Reply With Quote
Old 05-18-2009, 06:11 PM   #23
papagord's Avatar
1974 25' Tradewind
Midhurst , Ontario
L300 Motorhome Lock
[quote=DavidsonOverlander;689896]I'd be interested in hearing about what you can find locally - as I'm not located that far from you and the lock on my '74 Sovereign also has some issues. I haven't looked at it closely enough to see what needs to be fixed. You may already be aware of this, but if you decide to order the lock from Andy try to have it shipped through the post office, as the courier companies often charge exorbitant brokerage fees.
Hi Grant, I've just completed installation of an L300 Motorhome Lock (Bargman) on my Airstream. It did take some modification including the use of some aluminum to cover the hole and raising the striker plate up a bit. I had to replace the lock's inside flange with a piece of aluminum to accommodate the screen door but it looks pretty good. If you like I can send some pictures of the installation. I purchased the lock at RV Warehouse just off 400 near hwy 89.
Gord
Old 05-18-2009, 07:37 PM   #24
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
FYI,
The factory store sells the original KT assembly, I saw a few of them on the shelf. However, be forewarned they are VERY pricy!! I think it was around $400.
But if you are lookin got retain original fit and function.......?
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 05-19-2009, 08:16 AM   #25
papagord's Avatar
1974 25' Tradewind
Midhurst , Ontario
I failed to mention that the whole thing cost me $180.00 (Canadian) including the extra aluminum. To purchase anything in the US would cost me the exchange, plus shipping, plus broker's fees and tax. $180.00 including tax, although still a lot for a lock, sounds much better than a possible $500.00 to $800.00 Cdn. No fault of US dealers but that's the reality of purchasing items from the US. I did spend a little more on specialty tools like snap ring pliers but I'll have them for other occasions.
Gord
1993 30' (late 92 model) Excella :: 1993 Airstream Excella1000 arcamedies Airstream Registry Discussions 2 07-28-2012 10:10 AM
Question regarding sleeping & eating in a 1978 28' Argosy.. Rick F Argosy Motorhomes 4 09-02-2011 12:40 AM
Argosy :: 1974 Argosy dlb56hdt Airstream Registry Discussions 0 08-19-2011 09:32 AM
Elsa :: 1972 Argosy Argosy 20 bobfowler Airstream Registry Discussions 0 08-19-2011 09:31 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 12:11 PM
