Old 03-14-2010, 10:14 PM   #1
balasharky's Avatar
1968 28' Ambassador
west point , Utah
Door lock 1968 28'
I have read lots of posts and now im more confuzed about what to do. I have all the pieces to this door handle. I am unsure what bargman model or part I may need. As you can see the striker is busted at the ends. Hope the pictures help a bit.
Name:	2010-03-14 21.52.04.jpg
ID:	98116   Click image for larger version
Name:	2010-03-14 21.52.29.jpg
balasharky is offline   Reply With Quote
Old 03-14-2010, 10:20 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That's a Bargman L100 special.
Old 03-14-2010, 10:25 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
www.inlandrv.com or www.vintagetrailersupply.com both would have them (and would others). As Terry mentioned it is the special, not the standard one you get at RV shops, the striker is longer than the standard L-100. Both places list them as having the machined longer striker bolt
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Old 03-14-2010, 10:31 PM   #4
The original -100 striker bolt was cast.
We learned that Bargmanns mold broke, about a year ago..
Airstream then came out with a machined "striker bolt".
Old 03-14-2010, 10:54 PM   #5
balasharky's Avatar
1968 28' Ambassador
west point , Utah
So there would be no way to really find a replacement striker? Do I have to buy the entire door handle? Thanks for all your input.
Old 03-15-2010, 10:24 AM   #6
The new style striker bolt will work fine, assuming the rest of the lock is OK.
Old 03-15-2010, 10:41 AM   #7
balasharky's Avatar
1968 28' Ambassador
west point , Utah
Andy what would you recommend. That I buy the new lock. Do you have the entire lock etc. And or the striker.
Old 03-15-2010, 10:58 AM   #8
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If you can get a machined striker bolt vs the cast one, do it. Mine broke exactly like yours. The broken pieces blocked the bolt so that it could not be withdrawn from the door frame, trapping me inside the trailer. One of the screw heads stripped out, necessitating removing parts with channel locks. To replace the lock, I had to remove the door's inner skin.
Extreme example, but the cast striker bolt has been the problem with both L100s I have had to replace.
Vaughan
Old 03-15-2010, 11:43 AM   #9
Only you can see the condition of the original lock.
If it's worn, replace it, as an assembly. Then it will probably only last another 40 years.
If you want to replace just the striker bolt, you can do that, but then you still have an old lock.
The correct striker pocket is made with Nylon.
1968 airstream Sovereign 28' NO RESERVE in TIDIOUTE PA eBay Watch Airstreams on eBay 0 08-31-2009 08:00 AM
1968 Airstream 28' Overlander Trailer Camper TRADE?? eBay Watch Airstreams on eBay 0 07-29-2009 08:40 PM
proud owner of 1968 28' (Ambassador?) Lyvettely 1966 - 1969 Ambassador 13 02-12-2008 01:40 PM
What to look for? - 28' 1968 AS Moni Dollars & Cents 13 04-12-2007 05:23 AM
Will my TV work towing a 28' 1968 Ambassador hazhoni Tow Vehicles 8 08-25-2006 01:33 PM
