01-29-2005, 11:11 AM
Door Lock
The door Opening/Locking mechanism on my 1987 failed. Airstream told me they could fix it for around $800.00 and stated "it wouldn't be pretty". This being completely out of the question, I contacted Andy at Inland RV. With his help I was able to fix the problem for less than $175. If anyone would like to see pictures or has questions let me know.
02-14-2005, 11:01 AM
Door Lock
I have a 1982 Airstream Classic Motor Coach that needs the door lock replaced. Can you send me pictures and information on what he did to get yours fixed.
Rodger
02-14-2005, 01:09 PM
1966 26' Overlander
Woodstock
I fixed the lock on my 82 MH for ten bucks. The tumbler failed, a common failure...it cracked and spun in the cylinder. This part is still available and can easily be replaced, although the key will thn chnage as well. Mine has worked well now for three years.
If you search the old threads here there is at least one on this topic.
02-15-2005, 05:33 AM
Door Lock
My whole mechanism seems to be bad. I stopped by an RV Store and all the replacement fittings where the wrong size. I would like to put in an electronic latching system with manual key access like some of the newer Classic models. Does anybody know much about that system?
02-15-2005, 10:35 AM
Corona
Mobile1
A Bargman L-300 lock works great in your Motorhome door.
It does take some fitting and trimming, but works great.
Even the factory says it works.
03-16-2005, 09:53 PM
Square lock / Rectangular hole
I saw a bargman l-300 and it was 5" x 5" square. The hole in the door is 4" X 6". Unless the door is reskined there will be a 1" x 4" peep hole left. Any suggestions or comments are welcome.
03-17-2005, 08:43 AM
Corona
The door, must be plated.
If not, then there isn't a lock that will cover the hole, "AND" be approved for motorhome use.
03-23-2005, 07:32 AM
Anyone have a picture of their exterior door latch on a '69? When we bought our '69 Safari, the entire exterior lockset was missing. I ordered a new one and strike plate. The lockset fits fine. However, the strike plate looks like it is mortised into the door frame. I have no hole in the door frame. So, I'm wondering if there is something else missing? The hole pattern on the door frame matches the hole pattern in the strike plate.
Thought?
03-23-2005, 09:08 AM
Corona
Terry.
Thanks for the photo's.
Your trailer is a 69, however, the door jamb is from a 70 to 72, which requires a different stricker pocket.
We have tried calling you, but no one answers.
Call us asap, and we will ship the correct striker pocket to you, post haste.
03-23-2005, 09:43 AM
Thanks Andy.
03-23-2005, 10:29 AM
Seattle
, WA
This is what I did when mine failed. Had to plate under the lock to cover any gaps.
2000 Ford E-350 Super Duty 418ci/6.8L Triton V10 21’ Chinook Concourse XL
03-23-2005, 10:32 AM
Seattle
, WA
...also put in a deadbolt for extra security. I felt that the RV lock was too flimsy. Now I don't mind leaving the MH alone for an extended amount of time. Now, the windows are a different story!
01-20-2020, 04:47 PM
1985 25' Sovereign
Visalia
This was posted a LONG time ago but I would love to see what you did. I have an 1985 Airstream Sovereign that I want to install a keyless entry lock. The interior portion of the new lock set will cover. However the exterior has a 1” gap at the top. If I can get a plate fabbed that will cover and still look halfway decent that would be wonderful.
Any ideas?
01-20-2020, 04:48 PM
1985 25' Sovereign
Visalia
Any ideas?
01-20-2020, 04:56 PM
1985 25' Sovereign
Visalia
Any ideas?
02-06-2020, 07:24 AM
2012 25' FB Eddie Bauer
Virginia Beach
Originally Posted by wy53 35y356
I am looking for anyone to guide me and help me understand what could I do with this so that I can order a set of keys to make the actual hardware work!
Thanks in advance
Why not contact a locksmith who can disassemble the lock, reset the tumblers and cut new keys. Making a backer plate to cover the hole outside? Find a metal worker who can cast aluminum OR someone who has a 3-D printer. You could even integrate a pull handle in the design.
