Old 01-29-2005, 12:11 PM   #1
Door Lock
The door Opening/Locking mechanism on my 1987 failed. Airstream told me they could fix it for around $800.00 and stated "it wouldn't be pretty". This being completely out of the question, I contacted Andy at Inland RV. With his help I was able to fix the problem for less than $175. If anyone would like to see pictures or has questions let me know.
moveinon is offline   Reply With Quote
Old 02-14-2005, 12:01 PM   #2
Door Lock
I have a 1982 Airstream Classic Motor Coach that needs the door lock replaced. Can you send me pictures and information on what he did to get yours fixed.
Rodger
Mobile1 is offline   Reply With Quote
Old 02-14-2005, 02:09 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I fixed the lock on my 82 MH for ten bucks. The tumbler failed, a common failure...it cracked and spun in the cylinder. This part is still available and can easily be replaced, although the key will thn chnage as well. Mine has worked well now for three years.
If you search the old threads here there is at least one on this topic.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 02-15-2005, 06:33 AM   #4
Door Lock
My whole mechanism seems to be bad. I stopped by an RV Store and all the replacement fittings where the wrong size. I would like to put in an electronic latching system with manual key access like some of the newer Classic models. Does anybody know much about that system?
Old 02-15-2005, 11:35 AM   #5
Mobile1
A Bargman L-300 lock works great in your Motorhome door.
It does take some fitting and trimming, but works great.
Even the factory says it works.
Old 03-16-2005, 10:53 PM   #6
Question Square lock / Rectangular hole
I saw a bargman l-300 and it was 5" x 5" square. The hole in the door is 4" X 6". Unless the door is reskined there will be a 1" x 4" peep hole left. Any suggestions or comments are welcome.
Old 03-17-2005, 09:43 AM   #7
The door, must be plated.
If not, then there isn't a lock that will cover the hole, "AND" be approved for motorhome use.
Old 03-23-2005, 08:32 AM   #8
Anyone have a picture of their exterior door latch on a '69? When we bought our '69 Safari, the entire exterior lockset was missing. I ordered a new one and strike plate. The lockset fits fine. However, the strike plate looks like it is mortised into the door frame. I have no hole in the door frame. So, I'm wondering if there is something else missing? The hole pattern on the door frame matches the hole pattern in the strike plate.
Thought?
Keyholeren is offline   Reply With Quote
Old 03-23-2005, 10:08 AM   #9
Terry.
Thanks for the photo's.
Your trailer is a 69, however, the door jamb is from a 70 to 72, which requires a different stricker pocket.
We have tried calling you, but no one answers.
Call us asap, and we will ship the correct striker pocket to you, post haste.
Old 03-23-2005, 10:43 AM   #10
Thanks Andy.
Old 03-23-2005, 11:29 AM   #11
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
This is what I did when mine failed. Had to plate under the lock to cover any gaps.
Name:	outer locks.JPG
ID:	11151   Click image for larger version
Name:	lock handle inside.JPG
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 03-23-2005, 11:32 AM   #12
Astrodokk's Avatar
...also put in a deadbolt for extra security. I felt that the RV lock was too flimsy. Now I don't mind leaving the MH alone for an extended amount of time. Now, the windows are a different story!
Name:	int. deadbolt.JPG
