Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 03-17-2007, 03:12 PM   #1
Zig
1977 22' Argosy 22
Seattle , Washington
Door latch woes
We have a late 70's model trailer that's been sitting several years. Now the door latch (outside) is just floppy loose. It will not engage the latch mechanism. The door is obviously in the locked possition and we can't get into the trailer. Any sugestions?
Mike Ziegler is offline   Reply With Quote
Old 03-17-2007, 04:12 PM   #2
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Hi Mike,
Welcome to the forums. Lots of helpful people here.
My door lock once broke leaving me locked out.
Mine is a '64 therefore a bit different.
I had to tap out the door hinge pins. Then the door just lifted out and off.
When reinstalling I drilled and cotter pinned the hinge pins to make it much harder to do again...as theft deterrent
On mine the problem was in the lock cylinder, accessible from the inside.
Safari64
Safari64 is offline   Reply With Quote
Old 03-17-2007, 06:18 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
the lock cylinder is a common failure. If you can get it apart you may find the Keeler lock cylinder to replace it, but it means you will then have different keys. Those cylinders have been discussed here before, please search fo that info.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-18-2007, 01:04 PM   #4
Zig
1977 22' Argosy 22
Replacement latch
Can a replacement door latch be purchased through a local dealer? Thought I'd check before I tear into the broken one. Thanks
Old 03-18-2007, 02:35 PM   #5
Bad KT lock.
A replacement door lock for your trailer, will require you to have the pink slip on your home handy.
There is a very easy way to get into the trailer, without touching the door lock.
Since a thief could use this information, I will not post it here.
Call me tomorrow and I will tell you how to do it.
800-8777311.
There also is a much cheaper lock kit available to replace the very expensive KT lock.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-18-2007, 02:37 PM   #6
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Latch problem
I assume the latch is the same as the one on our '83 310 Moho. No longer
made from my research. Anyone know for sure? I had ours repaired by a
local locksmith that had the foresight to collect old latches. It's a "weak
sister" as far as I'm concerned & not looking forward to it failing, tho the
locksmith said the innards are bulletproof.
Me & "Bess"
Mike Leary is offline   Reply With Quote
Old 03-18-2007, 02:47 PM   #7
Me & "Bess"
Airstream motorhome entrance door locks are far removed from Airstream trailer entrance door locks.
The KT lock, does not exist any where, except in the Airstream trailers from 1970 to 1977. Parts are not available from any locksmith for those locks. The repair parts, while also expensive, are available from some dealers.
It's last price from Airstream was over $600.00, (not installed).
Not a good thing for owners.
Andy Rogozinski
Inland RV Center
Corona, CA
Water Heater Woes airstreamcaravel Water Heaters, Filters & Pumps 3 09-07-2005 09:18 PM
Refrigerator woes Pahaska Refrigerators 4 11-23-2002 12:14 AM
upload woes carmen Our Community 8 10-05-2002 04:21 PM
Review Woes uwe Forum Admin, News and Member Account Info 7 09-20-2002 11:13 AM
Armstrong A/C Woes on 71Sovereign MikeT Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-14-2002 12:09 PM
