Old 08-23-2010, 02:14 PM   #1
jnd
1976 31' Sovereign
Norris , Tennessee
Door latch broken
I'm having problems with the door latch on a '76 Sovereign. The key will turn the lock and I can feel it pass the point where the lock releases, but the door handle does not seem to be attached to whatever it is that pulls the plunger loose to open the door. Any suggestions that don't involve a crow bar or breaking a window???
jnd is offline   Reply With Quote
Old 08-23-2010, 06:19 PM   #2
x
XXXX , XXXX
Contact Andy at Inland RV. He has a method of entry that will not damage anything. He will not post it here so as to avoid tipping off thieves. It sounds like to me that the split pin on the striker post has broken and will not allow the handle to move the striker. Once inside you can remove the lock set and see the broken pin. It is easily replaced and you should be able to purchase it at any fastener supply or hardware store. I attached a pic for you.
Name:	Door Lock Split Pin 001.jpg
wasagachris is offline   Reply With Quote
Old 08-23-2010, 07:24 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The Andy method should get you in, but in case it does not, you may be able to yank out the tumbler/ key mechanism, but check out replacement first. Should be a standard item available through locksmiths. If that is a KT200 lock some parts are very expensive to replace. Once you get in you may want to talk to Inland RV about upgrading to their replacement lock kit. It's cheaper and reliable.
Old 08-24-2010, 05:05 AM   #4
jnd
1976 31' Sovereign
Norris , Tennessee
Door latch broken
Thank you all so much for your help. I'm going to try the Andy entry method and see what happens next!
Broken Inside Door Latch Mike Eagle Doors & Locks 4 01-08-2011 06:20 AM
Broken Door Latch Ranger 6 Doors & Locks 4 09-24-2009 08:23 PM
Screen door latch broken redeagle313 Doors & Locks 5 04-20-2009 05:03 AM
Door Latch broken on '75 Argosy debpatch Doors & Locks 4 05-26-2008 10:32 AM
Broken Door Latch Ranger 6 Doors & Locks 2 12-20-2005 05:55 PM
