Old 03-23-2012, 03:48 PM   #15
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
SafariSS,
I just performed your strike bolt adjustment. I had to move mine down a bit. I used a block of wood and a hammer after loostening to knock it down. I got it to move about an 8th of an inch. The door closes much better now. By the way, mine is a 3/4" hex head bolt.
Thanks for the tip.
David
10Smiles is offline   Reply With Quote
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
Propane holder adjustment 3Ms75Argosy LP Gas, Piping, Tanks & Regulators 9 07-10-2003 11:07 AM
Ignition timing adjustment PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 9 04-20-2003 08:22 PM
Pilot light adjustment thenewkid64 Water Heaters, Filters & Pumps 9 02-25-2003 04:04 AM
Load Leveling Hitch Fine Adjustment Road Ruler Hitches, Couplers & Balls 1 02-23-2003 11:32 AM
