Old 03-09-2004, 02:24 PM   #1
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Door Latch 1994
My door latch is showing signs of wear. The thumb latch deadbolt is broken and the spring loaded catch mechanism is badly worn. Is this a part that I can purchase through Airstream or do I need to make plans to have this one repaired. Some weld build up on the catch with some file work afterwards and a 1/4 20 stud drilled and tapped into the existing deadbolt with a piece of round stock attached to form the broken deadbolt would make a 1/2 way decent patch.
Does anyone know the manufacturer of this lock?
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
