Old 04-30-2016, 01:08 PM   #1
Door latch
I have a 71 sovereign that the main door latch won't lay flat. It works just fine but the door handle will not lay all the way flat. Any suggestions on why this does this or how I could fix it would be great! Thanks
njwgunner is offline   Reply With Quote
Old 04-30-2016, 02:37 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you have the original latch it is a KT200. The latch and parts are very expensive. You can get parts from Inland RV in California, and maybe Vintage Trailer Supply. Sounds like the lock needs to be lubricated and/or have a spring replaced. Inland RV used to do the repairs. Several screws and bolts hold the lock in the door you could try removing it, clean it as best you can, and silicone the moving parts. Inland RV also sells a replacement lock. This lock requires some modification to the door to make it fit. If you go this route don't throw out the old lock. You could probably sell it for parts for about as much as the replacement.
Lumatic is online now   Reply With Quote
Old 04-30-2016, 03:28 PM   #3
Name:	ImageUploadedByAirstream Forums1462051716.574360.jpg
ID:	261593Click image for larger version
Name:	ImageUploadedByAirstream Forums1462051733.909142.jpg
Old 04-30-2016, 03:29 PM   #4
This is what the latch looks like and that's as far in as it will go. Thank you for the info!
Old 04-30-2016, 03:37 PM   #5
De Soto , Wisconsin
Help
Sorry to interrupt your question, but how does a person start a new thread/question on here? Thanks
RT Pedretti is offline   Reply With Quote
Old 09-26-2016, 02:07 PM   #6
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Did you ever get a solution for this. I have the same issue on my Argosy.
Cheers....John
1977 24ft Argosy - sold.
Picinisco is offline   Reply With Quote
Old 11-03-2016, 06:20 PM   #7
1974 31' Excella 500
Chicago , Illinois
I also have this problem. Low on the todem pole at the moment though.
raphspeaks is offline   Reply With Quote
Old 01-26-2017, 12:49 AM   #8
1975 31' Sovereign
San Jose , California
The cause is: whoever drilled the hole in the rod that holds the flat handle has put it in such a place that the handle sticks out. You can
A) replace the rod and re-drill the hole
B) use the existing rod and re-drill both the rod and the flat handle in a new location
C) slot the handle so it'll sit flat, though it may "flop" around unless secured.
I just broke the pin that sits in said hole and connects the two pieces together, so I'll see if I can get some photos of mine in the next few days, since the flat part of my handle now flops uselessly.
Dobergirl is offline   Reply With Quote
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
'74 Sovereign screen door / door latch? texasbound General Repair Forum 2 09-23-2012 05:48 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
door in door latch richie rich Exterior Storage Compartments & Access Doors 3 10-07-2009 09:02 PM
Door latch/lock McGill Doors & Locks 0 06-25-2002 06:51 PM
