Old 06-09-2010, 12:44 AM   #1
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
Door key turns but doesn't lock
Hi everyone, this is my first post!
I just bought my Airstream today and will be picking it up tomorrow! It's in darn good shape except for a few little things, including the front (side) door lock. The key turns but it doesnt have any effect. I don't know if I should try my hand at taking the lock out and seeing if I can buy a new cylinder from the locksmith or what to do, but it definitely needs to lock. Does anyone have any suggestions? Thanks!
MonaxLisa is offline   Reply With Quote
Old 06-09-2010, 07:30 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Most of the parts for the lock are available from Out of Doors Mart. When I was looking for a lock cylinder my local locksmith could not get anything to replace it. At Out of Doors Mart also has a schematic of the lock with all the parts. Airstream Lock 1970-77
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 06-09-2010, 11:18 AM   #3
MonaxLisa's Avatar
good grief, I'm not sure I could do it myself, looks way confusing to me!
Old 06-09-2010, 12:55 PM   #4
1969 25' Tradewind
1983 34' Limited
Images: 85
It looks harder than it really is. If you can get the lock off just look to see if something looks amiss. When taking the lock off the door make sure you push the bolt in as you remove the lock off the door. The PO removed mine and broke the outer face of the lock. It isn't hard but that little mistake messed up my lock. I am letting you know about the bolt because anyone who hasn't removed one could do the same mistake.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Old 06-09-2010, 04:03 PM   #5
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
not hard at all, really. if you can get the lockset out of the door, you could also hand it off to your locksmith for the repair, and reinstall it yourself, or pay them for that, too.
for that matter, there's probably a dozen or more members here that would make the repair for you for free, if you wanted to cover the postage to send the parts!
obtw, buying an older Airstream virtually means that if you weren't handy before, you're about to learn!
best wishes for you and the new trailer. you'll do fine! lots of good information & support can be found here.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 06-09-2010, 06:38 PM   #6
1970 27' Overlander
Salt Lake , Utah
door lock
Try the easiest thing first. On mine the key must be turned one full turn
Oly10 is offline   Reply With Quote
Old 06-09-2010, 07:08 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
On mine the key only has to be turned 1/2 turn, but the teeth on the key always have to be pointing towards the read of the trailer. If I rotate the key with the teeth facing towards the front, the door will not unlock or lock.
Richard
Old 06-09-2010, 11:39 PM   #8
MonaxLisa's Avatar
Well I fiddled with it a little today and it seemed to be working for a few minutes. I'm going to try and get it off tomorrow though to see if a spring is broke or something like that. With the Airstreams, are the locks supposed to continue to rotate when you turn the key, instead of just going so far befor you turn it back (like a normal lock) or is mine definitely broken (it just goes 'round and 'round)
Old 06-10-2010, 02:51 AM   #9
freejack5555's Avatar
Scottsdale , Arizona
They do go round and round. Do you have an inside lock lever? If that is missing then that shaft will spin and the lockset wont engage. Its a very weird design but very simple at the same time. I just went through this door handle mess two days ago. One word of caution is to treat that door handle like a princess because she is VERY expensive to replace.
freejack5555 is offline   Reply With Quote
Door lock key - 1956 RankAm 1956 - 1959 Flying Cloud 8 10-03-2009 12:57 PM
Key Turns and Turns..is this normal? help shiny1973 Doors & Locks 10 11-25-2008 04:57 AM
Entry door bolt lock with an outside key willyd Doors & Locks 4 06-22-2008 01:07 PM
Missing Key for Potable Water Lock Door Streamer1 Doors & Locks 16 03-25-2007 08:00 PM
