Old 11-24-2006, 09:26 PM   #1
dezelfeder's Avatar
Question Door Issue
We just purchased a 1970 27' overlander. Previous owners had failed to shut the door during transport and it had flung open damaging the interior shell( All bent almost in half midway). After removing the shell I also noticed cracks in two area's of the frame. The door as is does close but does not seal properly at the top or the bottom.The cast iron hinges are also cracked but still work. Does any one know where we can look for a door and hinge set, or shall we pursue welders and repair on the existing door??
dezelfeder is offline   Reply With Quote
Old 11-25-2006, 12:05 AM   #2
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
Welcome to the forums! This is the place to find the answers you need!
On the top of the page is a blue toolbar, try the search function with different phrases such as "door damage" or "door hinge", etc. You may find posts or threads with a model such as yours.
I do know that bent doors and such are a difficult at best issue to solve.. If the door does not seal properly, you will have water leaks, which will rot your floor eventually... the hinges may or may not be available. Try InlandRV.com or VintageTrailerSupply.com for parts. You may need to repair what you have.
I would take some digital photos and post them in this thread... click the go advanced button after your key your questions, statements, and you can upload your photos. The pictures are really worth a thousand words here. People can respond much easier.
Good luck! And, again, welcome to the forums!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 11-25-2006, 04:48 AM   #3
Silver Mist
LI Pets's Avatar
Riverhead , New York
You can't weld the cast iron hinges, they need to be replaced.
see salvage yards
THe alum frame that has cracks can be welded.
If you can post a pic that would help
Old 11-25-2006, 06:39 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Try Colaw RV Salvage. It all depends on what they have in the yard.
5 meter Langford Nahanni
Old 11-25-2006, 06:49 AM   #5
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
That is the reason no matter what we alway's bungie cord our door when we are traveling. The past owner had problems with the door before and it looks like our door was replaced once.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 11-25-2006, 07:25 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums. I am very sorry to hear about the the mishap with your new Airstream. Rest assured that others here have had the same problem and help is on the way. I was able to return the original shape to me door by using a homemade jig and a com-along but yours sounds like more damage than just being sprung.
Chaplain Kent
Forest River Forester 2501TS
Chaplain Kent is offline   Reply With Quote
Old 11-25-2006, 08:48 PM   #7
1960 24' Tradewind
santa barbara , California
you can also try cherokee Rv salvage in colorado ,they do get airstreams in
from time to time ,had a couple in, a few months back .
Scott
scottanlily is offline   Reply With Quote
Old 11-25-2006, 10:54 PM   #8
dezelfeder's Avatar
Thank you for all the responses, I will be calling a few places for the hinges, and as to the door I have found a guy here in town that does aluminium welding. I will probably try the 2X4 in the door jam to get things straightened out as well. Will keep every one posted as to the results.
