Old 07-31-2011, 07:17 AM   #1
rayandre's Avatar
1970 27' Overlander
Shaker Heights , Ohio
Door is hard to close
We had the main door seals replaced on our 70 Overlander including the screen door back in Feb at the factory. The main door was never super easy to close from the outside but it's a bit tighter with the new gasket and when you want to shut the main door from the inside you have to slam the heck out of it to get it to shut. The original lock works fine but I'm wondering if there's a way to make it latch easier? Don't want to wake up the neighbors trying to close my door!
rayandre is offline   Reply With Quote
Old 07-31-2011, 08:15 AM   #2
Lube the entrance door striker bolt and striker pocket with "silicone spray".
It does an amazing job making the door close "MUCH" easier.
Old 07-31-2011, 08:22 AM   #3
Riverrat6270's Avatar
1980 31' Excella II
Springfield , Illinois
I have an '80 Excella and the axles are due to be replaced. If the unit is perfectly level the door shuts perfectly, otherwise its a problem. Might look at your axle situation. I even thought I had a problem with the latch. Silly me.
Riverrat6270 is offline   Reply With Quote
Old 07-31-2011, 08:22 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would first swing the door towards the closed position and try and note where the resistance changes from hinge friction to resistance because of the gasket compressing. The large the angle at which you note resistance from the gasket will give you an idea of where the problem is.
If that angle is say greater than 10 degrees the hinge side of the gasket is being compressed TOO soon and could be reduced if you pad out the hinges against the trailer body.
If the door almost reaches the latch and a last heavy nudge will latch it you may be able to just adjust the strike plate, on the door frame, out to reduce the effort necessary to latch the door.
As a last resort you could file the tongue back. If you do this be sure not to introduce a taper to the face of the tongue as this will keep the latch from seating all the way and may result in the door flying open while on the road.
2004 Excursion 4x4
Old 08-01-2011, 01:38 PM   #5
rayandre's Avatar
1970 27' Overlander
I thought I had lubed it all up but I'll check that first and then see where it's having trouble. I know it's not an axle issue since we just had both axles replaced a few months ago. I'm inclined to think it's the new gasket but I'm reluctant to change that since it seals really well. Thanks!
Close Calls masseyfarm On The Road... 78 01-30-2017 08:25 PM
How do you close the door- 2010 Classic? AirHedz 2006 - 2010 Classic (all lengths) 19 03-04-2012 04:07 PM
New Curtains - My wife's hard work. montanablue Upholstery, Blinds, Walls & Interior Finishes 10 08-08-2011 09:58 PM
McGrath State Beach in California to Close OB Bambi Airstream "In the News" 0 04-15-2011 07:55 PM
Water Hose - Hard Water Deposits Al - K4GLU Fresh Water Systems 4 02-16-2011 04:00 PM
