Old 11-19-2006, 03:31 PM   #1
1972 31' Excella 500
Ozark , Missouri
Door hinges loose
The hinges on my '72 are getting loose, and the door jamb does not appear to be one that is easily removed. Are the holding bolts attached with interior nuts, or are they simply stripped out?
Blimphauler is offline   Reply With Quote
Old 11-19-2006, 04:55 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Hey Blimphauler, If your hinges look like pic number one on the outside, then they probably look like pic number two on the inside. Hope this helps a bit.
I gotta ask, how does a guy that lives in tornado alley come up with a user name like Blimp Hauler?
ID:	28810   Click image for larger version
www.nesa.org
Air No. 6427
Old 11-19-2006, 05:35 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Good timing for the pic, have a loose hinge on the Overlander. They have Elevator bolts. Looks like two have backed off a bit
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-19-2006, 05:38 PM   #4
Ozark , Missouri
Pictures coming
Thanks for taking the time to post the pix! Mine's a bit different, and I'll get pix to post in the next day or so.
As for the username, the goal is to get out Dodge as soon as it gets to be that time of year. The AS is our escape capsule - so far so good, but I'll be much happier once we're out of the crosshairs...
Old 11-19-2006, 05:44 PM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I just repaired my loose door hinges.
What I discovered was that the original nuts had star washers attached to the nut, the star washers rusted out and that was the cause of the play between the hinge and body.
I replaced the nuts with nyloc's
Michael
ArtStream is offline   Reply With Quote
Old 11-19-2006, 06:24 PM   #6
1976 25' Caravanner
Campton , New Hampshire
Has anyone replaced just the pins ? It looks like they only go in from one side , no way to knock them out .
ticki2 is offline   Reply With Quote
Old 11-20-2006, 02:35 PM   #7
The double hinges for the entrance door were first used in mid 72 and up.
You could possibly have a 73.
The hinge pins come loose because of severe vibration when towing. You should balance the hub, drum, tire and wheel as an assembly.
You should also check the striker pocket for wear as well as the lock striker bolt.
Drive the hinge pins back into the hinge. Using a center punch at the top of the hinges, dimple the hinge to hold the pin in place.
That will eliminate the need to replace the hinges.
CAUTION: If you do not properly balance the running gear, the pins will again come loose.
At that point, the hinges must be replaced.
Pins for that hinge are not available.
Old 11-20-2006, 03:22 PM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Hey Andy! That is real good info!
www.balrgn.com
How not to loose a hubcap qqq Wheels, Hubs & Bearings 14 03-31-2003 06:37 PM
Anyone else loose the forum today? Silvertwinkie Off Topic Forum 15 03-08-2003 01:58 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
moved and tore loose what happened overlander General Interior Topics 5 09-24-2002 06:50 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
