Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Prev Previous Post   Next Post Next
Old 09-03-2006, 04:11 PM   #1
BAUXITE
Ed Keyes's Avatar
Profile:  2004 25' Classic
homosassa , Florida
Question Door Hinges
Have a 04, 25' Classic. The bottom pin in door hinge on the entrance door wants to come lose after a few hundred miles. Airstream repair dealer notched the pin and inserted a rivet in the hinge to hold in place. This lasted for about 800 miles and started to "rise" again. Called Airstream and the person I spoke with said he never heard of this problem before. Most of the problems he encountered were pins that were "frozen". His advise was to use a punch to return the pin and notch the hinge around the pin with a tool similar to a cement chisel. Just returned from 6K mi. trip and had to do this ever 200 to 500 miles. Anyone else had this problem ? If so, what did you do to fix. The only other thing I can think of is to have the pin notched in a machine shop, tap the existing hole in the hinge with a allen screw and insert. My concern with this approach is that the hinge looks to be cast aluminum and not sure it is strong enough to hold the screw.
BAUXITE
Ed Keyes is offline   Reply With Quote
