Old 08-10-2004, 09:25 PM   #1
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
door hinge worn not the pin
There are threads about problems with the door hinge pin and also adjusting the door by loosening the hinge but has anyone tried to have the worn hinge holes drilled out to the next size larger and putting in a larger pin?
Silver 67
silver 67 is offline   Reply With Quote
Old 08-11-2004, 07:09 AM   #2
LOST , Hawaii
Drilling will give to much slop for a long term fix, they should be bored or reamed. All the set up time will cost more than new hinges.
John
74Argosy24MH is offline   Reply With Quote
Old 08-11-2004, 08:55 AM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
But John, therein lies the rub. The hinge for a 67 is not available. The pin is. option one is to find a door in a bone-yard. You will have to buy the whole thing to get the hinge Or have a machine shop re-bore the pin hole and make a new pin for the door.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-11-2004, 09:53 AM   #4
LOST , Hawaii
If that is the way you have to go make sure that they put in bushings. They will be cheaper to replace in the future once the machining is done, they can be bored for a stock pin.
John
Old 08-11-2004, 06:14 PM   #5
Tinsel Loaf's Avatar
John is right on. Make several bushings so you will have replacements. Bronze bushings are easy to make however the metal is soft. Just keep em well oiled.
Tinsel Loaf is offline   Reply With Quote
Old 08-11-2004, 08:30 PM   #6
silver 67's Avatar
1967 30' Sovereign
Thanks guys for all your comments. That confirms the direction I was thinking about going. Guess I'll be ordering a new pin from Andy so I can get the right size bushing. Just put new weather stripping on the door and have noticed that I have to pull up on the door a bit to close it properly and not ruin the stripping.
Two steps forward, one step back.....
Thanks again
David
nine pin connector driftwood Electrical - Systems, Generators, Batteries & Solar 2 09-24-2003 11:45 AM
Need 7 pin wiring help. TBKP's Overlander Electrical - Systems, Generators, Batteries & Solar 3 04-21-2003 01:27 PM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 08:04 AM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 10:26 AM
