Old 07-24-2006, 06:06 PM   #1
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
Question Door Hinge Pins on 79 Excella
The screen door has some cracks in it on my 79 Excella 500. I would like to have them welded but I need to ship it off to my nephew 150 miles away so I was going to remove the screen door and leave the outside door on the trailer. However, I can't figure out how to get the hinge pins out, there is not an access hole on the bottom to punch them out and I've read elsewhere that the screws that hold the hinges on the trailer are attached with nuts Ha must be gotten to, to remove. I guess I could pull the trailer to Kansas but that seems extreme, so what is the best way to remove the screen door , if any?
Dan
Dano57 is offline   Reply With Quote
Old 07-24-2006, 07:35 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Drill a 1/8 " hole up from the bottom & use a small punch to drive the pin up.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
31' Excella 500 davidz71 1977 Excella 500 5 06-28-2007 09:15 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
