Old 09-04-2005, 01:47 PM   #1
65 overlander's Avatar
Images: 22
Door hinge pin?
I'm in the process of closing up the play in the main door & screen hinge, by inserting bronze tube bushings. I plan on enlarging the the holes just slightly to insert the bushings, but my question is,It looks like there is a small pin locking the hinge pin in place, and I need the best way to tap out the pin. Any info would be great!
65 overlander is offline   Reply With Quote
Old 09-04-2005, 07:40 PM   #2
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
hinge pin removal
I just remove our hinge pin this summer on our 1967 Airstream. It had what is called a roll pin that helped hold the hinge pin in place. You just need to find a punch that is small enough to tap the roll pin out. It should tap out from either side. The hinge pin was a different animal. It had one end that was larger than the other end. I do not remember which end was larger. I just remember that it came out easier one way than it did the other. I also used a lot of WD40 in the process.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 09-09-2005, 10:42 PM   #3
Images: 22
Sorry to get back so late! Got a punch set and I'm waiting for a day off to work on it. Thank you for the reply!
Old 09-10-2005, 01:04 AM   #4
You may wish to consider the probability of electrolytic corrosion between aluminium and bronze. This link shows the voltages in the galvanic series.
http://www.corrosionsource.com/handbook/galv_series.htm
I would not use this combination. Stainless steel would be better, IMHO.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
1978 24ft Argosy brakes juel Brakes & Brake Controllers 6 10-31-2004 04:14 PM
Need 7 pin wiring help. TBKP's Overlander Electrical - Systems, Generators, Batteries & Solar 3 04-21-2003 01:27 PM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 10:26 AM
