Old 05-09-2011, 01:57 PM   #1
1978 23' Safari
EL Paso , Texas
Door hinge on 1978
Door hinge on 1978 23' Safari. The two door hinge screws no longer hold. Threads in frame are stripped. What is process to get screws to hold to stripped frame holes?
James Moore is offline   Reply With Quote
Old 06-18-2011, 04:47 PM   #2
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
I have the same issue. Only 1 screw will screw into anything.
tcrum is offline   Reply With Quote
Old 06-18-2011, 05:46 PM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
I've used a product called Rivnuts to repair threads from the 'outside'...
Check here: Rivnut Fasteners & Bollhoff Installation Tools, Puller EZ & Custom Rivnuts - Blind Fasteners & Inserts - Bollhoff the video in the middle shows an installation...
You can get alum rivnuts, but you'll need the special tool to install them properly...
here's another look... http://www.aimfasteners.com/about_rivnut.html
Ray & Pat; Morada, CA
Old 06-18-2011, 06:28 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Drill all the way through, put a SS bolt washer and acorn nut on will last for ever.
'77 Sovereign Intl 31' CB
1978 Airstream 31 foot eBay Watch Airstreams on eBay 0 03-27-2011 09:40 PM
1978 Airstream eBay Watch Airstreams on eBay 0 03-25-2011 01:01 AM
1978 25' Total Redo Hofarc83 Member Introductions 4 02-23-2011 06:38 AM
Vintage Avion (Like Airstream) - 26' Camper circa 1978 eBay Watch Airstreams on eBay 0 01-31-2011 01:50 AM
