Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 07-27-2004, 08:10 PM   #1
paddy79
Profile:
Door hinge lubricant
I sprayed silicone on the exterior door hinges of my 79 Sovereign - yikes, what a mistake! Now it creaks & groans loud enough to wake the dead. Anybody got an idea of what I should have used? Do I need to take the hinges apart and clean this stuff off? I"ll appreciate any sage advice. I searched the forums (and my service manual) but couldn't find any info.
Patrick
paddy79 is offline   Reply With Quote
Old 07-27-2004, 09:38 PM   #2
MW64OVERLANDER
MW64OVERLANDER's Avatar
Profile:  1964 26' Overlander
Norman , Oklahoma
Images: 67
Patrick,
I have found silicone to be a poor long term lubricant for most applications. Use a good white litium spray lubricant for the door hinges. I don't think you need to take the hinges apart to clean the silicone off.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 07-27-2004, 09:45 PM   #3
JohnG
JohnG's Avatar
Profile:
I use WD-40. It works on a lot of things to stop squeaks and so forth.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Trouble Drilling to Install Anti Sway Cams DEO Hitches 21 02-26-2004 06:15 AM
coconut oil lubricant for drains murphy Waste Systems, Tanks & Totes 9 05-12-2003 09:01 AM
Help!! exterior outlet cover stuck DIMMER Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 12:04 PM
