Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 07-04-2003, 08:23 AM   #1
Door hinge/frame damage
I recently damaged the door frame by catching the lower hinge on a fence post as I parked my 76 Argosy. The hinge caused the frame to twist slightly and now the door won't close properly.
I presume that I can reverse engineer my way to a repair by somehow grabbing the hinge and pushing it in the opposite direction until I achieve original position. Is this the wrong way to make this kind of repair? If so, what is the proper way of doing it and is this beyond the ability of an average tinkerer? It looks like I'll have to remove the refridgerator and the interior cover to get access to the frame if that's where the repair needs to be made. I've never tried a repair like this but have plenty of time on my hands. I don't know how much something like this would cost if I took it to a certified Airstream repair place but that wouldn't be very easy either. The closest one is about 190 miles away.
Dennis Fahlstrom is offline   Reply With Quote
Old 07-04-2003, 11:50 AM   #2
LOST , Hawaii
The hinge actually bolts through the skin. If you try to push it back into position you might tear or distort the skin. If the frame(s) are severly bent you are going to have to remove some rivets as the skin is a substantial part of the structure and will resist straightening.
John
74Argosy24MH is offline   Reply With Quote
Body damage repair AccessMaster Airstream Motorhome Forums 0 08-14-2003 11:07 AM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 08:34 AM
Exterior Damage BRH Ribs, Skins & Rivets 1 12-07-2002 08:32 AM
ultra violet damage bhsl8 Tires 10 11-10-2002 03:03 PM
Hail Damage jcanavera Our Community 4 03-30-2002 09:24 AM
