Old 05-23-2004, 05:48 PM   #1
Door Hinge for '72
Can anyone tell me where I might find a door hinge for a 1972 Ambassador?
Thanks Grant
garntmcclintock is offline   Reply With Quote
Old 05-23-2004, 06:15 PM   #2
They don't exist.
However, you can replace the hinge pin.
You can also reposition the hinge to compensate for wear.
Old 10-02-2010, 03:27 AM   #3
1969 27' Overlander
San Diego , California
1969 Overlander Door Hinge question
Where can I find instructions for replacing the hingepin and/or adjusting the door hinge on 1969 Overlander.
The door is getting progressively harder to close. I can see wear on the door frame where the screen door is making contact. It was minor, but the as the door gets harder to close, the wear mark on the screen door and the door frame is getting longer.
We're having to pull harder and harder on the door knob to get the door to latch.
Also: there is a difference in the gap from the top to the bottom of the door on the hinge side. It's wider at the top. Almost no gap at the bottom.
Could this be due to the hinge pin wearing out?
thanks,
Jai
SunDiego is offline   Reply With Quote
Old 10-21-2010, 09:13 AM   #4
pinktrailer's Avatar
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Originally Posted by Inland RV Center, In View Post
They don't exist.
Andy--I just checked your website, and didn't find the hinge pin listed. I have a '67 overlander that needs a new pin. Thank you for any info.
pinktrailer is offline   Reply With Quote
Old 10-21-2010, 09:18 AM   #5
Look for part # 19450 on our web site.
Old 10-21-2010, 10:02 AM   #6
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Got it, thanks, I will be ordering it, and the lock for my '53, if you have that as well.
The pin in my hinge was hanging out of the bottom of the hinge. I tapped it back in, only to notice that the pin had been repaired at some point. It looks like it is in two pieces, with something added in the middle to hold it in. Can't remember now if it was a rivet, or what.
Do I just "tap in" the new pin?
Old 10-21-2010, 11:00 AM   #7
You should see where a "split pin" was inserted about midway in the hinge, that partially went thru the hinge pin. That split pin holds the hinge pin in place, after you tap it in place and then drill a small hole thru it for the split pin.
Make sense?
Old 10-21-2010, 12:41 PM   #8
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Make sense?
Absolutely.....only question is, it sounds like maybe my hinge pin is not broken, but since it was slipping down, and out of the hinge, do you think I just need to put in a new "split pin"?
Old 10-21-2010, 12:53 PM   #9
I have no idea. Is the hinge pin the length of the hinge?
Old 10-22-2010, 09:03 AM   #10
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
I am just going to order one, and when I install it, I will find out if the other is broken or not. The fact that it is slipping down is enough of an issue for me. Thanks for all the help.
Old 10-22-2010, 09:49 AM   #11
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Make sense?
Andy--I just ordered the hinge pin. I didn't find a "split pin" on your parts list. Does it come with one? If not, could you please either add it to my order, or let me know where to get one? Thanks
Old 10-22-2010, 10:39 AM   #12
The split pin must match the hole that's in the hinge body.
I do not know what size that is.
Hardware stores, Home Depot and the like have the split pins.
They are very cheap.
Old 10-22-2010, 01:41 PM   #13
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Makes sense. Thanks Andy!
Old 10-22-2010, 04:22 PM   #14
1969 27' Overlander
