Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 07-02-2019, 01:18 PM   #1
Rltports's Avatar
2015 25' Flying Cloud
Bettendorf , Iowa
Door hinge flex
So I am probably just being too obsessive but today I noticed the bottom hinge flex slightly when I closed the door. The top hinge doesn’t move. As you might see in the picture there is a slight gap that appears around the hinge when the door is closed. I reset the stabilizers just in case and no change. The door closes nicely but I am wondering if this is an indication I should be tightening the hinge. With that said, there is no obvious way to do that. Any comments are welcomed. Even if it is to forget it and go buy some steaks for the weekend.
Rltports is offline   Reply With Quote
Old 07-02-2019, 02:28 PM   #2
2019 25' Flying Cloud
Hendersonville , North Carolina
Tighten hinge screws
Pry the small piece of plastic trim off that is between the hinge points. This is the piece attached to the trailer. Two screws visible. Tighten. Done. The little piece of chrome plastic trim may or may not stick when you try to press it back on. You can buy it by the foot at dealer. Easy Peasy.
uraljohn is offline   Reply With Quote
Old 07-02-2019, 04:05 PM   #3
Wconley's Avatar
2018 28' International
Renton , Washington
Exactly what Uraljohn said. When we did this to our trailer we suddenly found that the door closed and latched much easier! Go figure.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 07-03-2019, 06:32 AM   #4
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
Had to do this twice to our door hinges on a 7300 mile trip across the country and back. I'd like to remove the screws one by one and re-install them with blue locktite on the threads to keep them tight.
Obviously the nuts the screws thread into are captive, or they'd spin around as they are tightened. I'd like to know if they are captive to a metal strip such that the two nuts for each hinge are attached to the same strip.
That way I can remove a screw to put locktite on the threads without fear of hearing the nut fall to the floor of an interior panel.
Anyone know? Or do I have to search through the parts catalog to find out?
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 07-03-2019, 08:21 AM   #5
dznf0g's Avatar
Oswego , Illinois
According to old threads, they are NOT captive and will fall within the wall if removed. This necessitates interior trim removal and a hole saw to repair. Loosen them at your own risk.
-Rich-
Old 07-03-2019, 09:03 AM   #6
Wconley's Avatar
Renton , Washington
YIKES! I never would have assumed this! I was going to use Locktite like Baby Zeppelin but I guess more caution is needed. Thanks.
Walt
2013 F150 Ecoboost
Old 07-03-2019, 04:50 PM   #7
Rltports's Avatar
Bettendorf , Iowa
Thank you to everyone for the replies and great discussion. We’ve had our 2015 25FC for 3 months and have found this forum to be incredibly valuable. I find it hard to believe that there could be a better community of users.
Old 08-19-2019, 05:30 AM   #8
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I noticed the same thing happening on our 2017 28’ International. I removed the cover and attempted to tighten the screws. They are tight but yet the hinge is moving slightly when we close the door. It closes tightly so not sure what is happening. I’m concerned the mounting point may eventually fail requiring a major door frame repair.
VaTravelers is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Pre-war Door Hinge (Door-in-door) ekstarr Doors & Locks 0 06-26-2018 02:37 PM
"Door in a door" hinge goshawks00 Doors & Locks 1 12-06-2016 04:00 PM
Looking for a door hinge for my 1950 Liner. Possibly a whole door. Thanks ! Gocamp2 Doors & Locks 0 05-31-2016 04:42 AM
"Water Heater" & SS Flex hose? Sneakinup Water Heaters, Filters & Pumps 15 01-31-2004 09:22 PM
