Old 09-14-2012, 09:50 AM   #1
1972 31' Sovereign
robstown , Texas
Door hinge
hello everyone,
i have a question about door hinges. my 72' sovereign has one big
hinge in the middle of the door. when i close my door it does not shut
well at all. I open it by lifting up (barely) with a touch of my finger.
when it is open all the way back, it can rock back and forth on the
hinge. you have to make it rock by holding each side of the door.
where can i get a new pin for the door? I am hoping it is just the
pin being worn down.
Thanks for all of your help.
silvergirl53 is offline   Reply With Quote
Old 09-14-2012, 02:25 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Worn Pin is Extremely Unlikely
Originally Posted by silvergirl53 View Post
... where can i get a new pin for the door? I am hoping it is just the pin being worn down...
Inland Andy, I believe, stocks new hinge pins.
The pin is steel while the hinge pieces are made of softer aluminum. It is highly unlikely the hinge pin is the problem.
In my case, the aluminum had wallered out. The only way to fix that is to either drill & bush the holes or replace the hinge pieces.
Seven years ago, I chose a different option:
http://www.airforums.com/forums/f453...tml#post182518
It still works like a charm.
Tom
