Old 12-24-2006, 11:10 AM   #1
dezelfeder's Avatar
Door Hinge
We have a 1970 27' Overlander with a broken entry door hinge. This is the single hinge that keeps the door on. It is functioning(barely), it is craked on the hinges on the door side. Material seems to be cast,can it be welded or where is a good place to look for the part?
1972 29' Ambasador
1970 26' Overlander
Tow w/h 2005 Dodge Ram
Cummings/turbo Diesel
dezelfeder is offline   Reply With Quote
Old 12-24-2006, 12:52 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I'm parting out an early 70s Ambassador. http://www.airforums.com/forums/308735-post8.html
The hinge will probably be an exact fit. Keep in touch.
Zep
Old 12-26-2006, 05:55 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Parting out
I would be interested in a couple of exterior compound skins. I would even rivet on my old ones to keep it towable. And I,m always up for a good barter.
Kip
Old 12-27-2006, 10:07 AM   #4
1975 31' Sovereign
1977 23' Safari
Originally Posted by Aerowood
I would be interested in a couple of exterior compound skins. I would even rivet on my old ones to keep it towable. And I,m always up for a good barter. Kip
Kip,
I'm going to keep one end intact for another member, but you can have the other. I don't know which end yet, front or rear. I'd take it apart at the stringer between the side panels and the curve by drilling out the rivets in order to keep the side panel skins whole. I haven't disassembled a shell yet, so I don't know how much work it will be.
I believe both ends are in good shape. I think an intact end, including the lower panels, will fit in the bed of a standard pickup (7' x 8' x 6' HWD). Getting this item back from Mojave to Denver might pose some unexpected problems, since the bed of my truck is usually full of other stuff. Message me in February.
If you're in a bind for parts, Cherokee RV Salvage in Westminster has some compound skins available and just announced that they have two other 70's Airstreams they are going to part out.
Roger
Old 12-27-2006, 10:39 AM   #5
1975 31' Sovereign
1977 23' Safari
Oops, just looked at the photos again (see thread "Dead in Baker") and you can see that the top center of the rear end panels are dented. Perhaps the other panels will be sufficient for your needs?
Zep
Old 02-16-2007, 10:00 AM   #6
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Did anyone take that door hinge? Mine, on the '66, has worn. Wondering if the hinges are the same?
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 02-16-2007, 04:35 PM   #7
Marti's Avatar
Images: 20
I saw a door hinge on ebay this week, dont know if it's still there or not?
Marti is offline   Reply With Quote
