02-16-2011, 04:31 PM
1973 21' Globetrotter
Virgin
, Utah
Door Handle/Latch needed
I need to replace the main door handle/latch on '73 . Mine has been butchered to put it politely. I can't afford a new one (shame) so looking for anything that is better than mine !
Not worried about having key/working lock, I've never had one so why start now  - I can move thd latch mechanism over from mine if need be.
Many thanks
Steve
02-16-2011, 04:53 PM
Princeton
, New Jersey
What is wrong with your latch? Almost anything metal can be fixed. I had to reweld the tongue on mine after it broke off. The spring will be the hardest part to remake.
2004 Excursion 4x4
02-16-2011, 05:47 PM
1973 31' Excella 500
Spring Green
, Wisconsin
I was able to find a new handle on ebay for a reasonable price. It has a small amount of damage at one corner that is purely cosmetic. I do want a handle that both latches and locks. After I switch it out next month, if I think the old one is of any value, I'll make it available here on the forums.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
02-17-2011, 12:43 AM
Virgin
, Utah
Doesn't show in the picture but it got sand or something (heavy file ?) and scratched up - then painted... from the picture its looks ok but to the naked eye not so good sadly.
02-17-2011, 12:44 AM
Virgin
, Utah
If I haven't got one by then I would be willing to make you reasonable offer.
02-17-2011, 06:21 AM
Spring Green
, Wisconsin
ukinusa, I'll let you know the condition etc., of my handle when I complete the installation of the new one.
Lew TAC #WI-6
02-18-2011, 12:45 AM
1973 31' Sovereign
Sacramento
Hey, I could really use any functioning exterior door handle for a '73. Someone broke the tongue/flange part off. No reasonable offer refused. Otherwise, any ideas?
02-18-2011, 06:40 AM
1971 27' Overlander
Central
, Ohio
Airstream Lock 1970-77
02-18-2011, 06:50 AM
1993 21' Sovereign
Colfax
, North Carolina
Originally Posted by Ganglin
Parts are also available for the lock, provided it isn't destroyed, from the same place as linked above.
02-18-2011, 07:51 AM
Ottawa
, ON
Many thanks
Steve
Do you have two trailers, or was the above a typo? (Your profile says you have a 1972 21' Globetrotter).
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
02-19-2011, 12:39 AM
Virgin
, Utah
Typo some where - just 1 ! Need to check my profile - thks for catching ;-)
02-19-2011, 07:17 AM
1993 34' Excella
Estancia
, New Mexico
Inland RV sells a new replacement kit for this lock that, if I remember right is around $150. They also sell a new lock same as the original which is much more expensive. The new lock also has a flush handle, I think, but is a different size. Installation requires some door modification, what exactly I am not sure.
There is a product called "Liquid Stainless" that I have wanted to try on my lock, but have not got around to it yet.
02-20-2011, 10:22 AM
Virgin
, Utah
Will look at that - I only saw the expensive 'look alike' lock which is beyond my pennies !
