Old 01-04-2004, 05:53 PM   #1
71Overlander
Richard Murphy's Avatar
1971 27' Overlander
door handle
We own a 1971 International Overlander and the exterior door handle broke. Any suggestions for a replacement?
Richard Murphy is offline   Reply With Quote
Old 01-04-2004, 06:12 PM   #2
Davydd's Avatar
Tonka Bay
Images: 13
How is it broke?
My door handle latch evidently had been broken in the past and someone (previous owner?) had it welded back together. Works OK now.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
Davydd is offline   Reply With Quote
Old 01-04-2004, 06:14 PM   #3
71Overlander
1971 27' Overlander
door handle
The handle is flat and it broke where the pin goes through it. The part that wraps around the pin broke off.
Old 01-05-2004, 09:36 AM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Cool Hope this helps
Here is a parts breakdown of that particular lock. You might try checking with Oasis RV . I was able to get parts for my lock in the past.
-Tim
theVAP - Airstream Podcast
Old 01-05-2004, 03:42 PM   #5
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
They apparently changed the lock design in '78. When mine broke, I went to the Airstream dealer in Fredericksburg VA and he quoted me a price of $125 for the kit to fix it. He said and I quote:"be glad you don't have a '77. The replacement kit is over $500".
Does anyone know of a repository for expired Airstreams that our friend might contact to get used parts?
BTW, my problem was the ears on the bolt subassembly were broken off and a friend brazed new ears on and it works fine.
Good Luck
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
http://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 01-05-2004, 03:55 PM   #6
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Yep. That is what I found out when I researched to repair my door lock on my '71. What I was told is the replacements are handmade. The parts breakdown I gave in my earlier post shows the lock used from 1970 - 1977. So you are very lucky!
Again, see my earlier post. Oasis RV had the parts I needed available and knew what I was talking about when I asked for it. Not cheap mind you but I got what I needed to fix my lock and a new lock cyclinder with keys. One of the easier jobs I had to tackle
-Tim
Old 01-05-2004, 06:33 PM   #7
aviontt's Avatar
, Connecticut
I welded mine ....Works GREAT.....
Worry will never change the outcome!!!
aviontt is offline   Reply With Quote
Old 01-05-2004, 08:02 PM   #8
71Overlander
1971 27' Overlander
Thank you for all of your suggestions. Welding sounds better all of the time.
Old 09-24-2004, 02:10 PM   #9
Handel
CAL Inland R.V. Center
909-734-8130 p/n 22065 k t vertical shaft $44.80 on 12-18-02
works on my 71 excella 31'
Rob
WATTSR is offline   Reply With Quote
Old 09-24-2004, 02:17 PM   #10
North Central , USA
Originally Posted by startrekker2001
...Does anyone know of a repository for expired Airstreams that our friend might contact to get used parts?...
Try Colaw RV (Junkyard) in Missouri.
RivetED is offline   Reply With Quote
Old 09-27-2004, 10:54 AM   #11
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Anyone have a pic of a welded repair they would post?
>>>>>>>>Action
